Scaling and offset of a sensor
Results 1 to 6 of 6
Threaded View
    Default Scaling and offset of a sensor
    I am a bit stuck in this offset and span measure of a pressure sensor.
    I use the MPXV5004DP differential sensor and it gives and offsset around 1 volt at 0 differential pressure with max 4.92 volts for 39.22 mbar differential pressure.
    So the span is 3.92 volts for 0-39.2 mbar, the offset depends on the device and may range from 0.75 up to 1.25 volts.
    I would like to make an semi-automatic offset calculation on first program execution. Then arrange the 0-39.2 mbar to 0-5 volts but am confussed on the maths.
    My A/D converter is 10bits. Any tip appreciated,
    Last edited by Ioannis; - 13th March 2023 at 16:17. Reason: semi to semi-automatic and some syntax mambo-jumbo
  1. Help with scaling math..
    By ardhuru in forum General
    Last Post: - 15th May 2017, 23:41
  2. Offset to variable howto ?
    Last Post: - 3rd October 2008, 09:36
  3. Scaling ADC values
    By purkolator in forum mel PIC BASIC Pro
    Last Post: - 29th November 2007, 05:14
  4. Help scaling voltage...
    By sirvo in forum Schematics
    Last Post: - 30th July 2007, 19:35
  5. Need help with scaling
    By champion in forum mel PIC BASIC Pro
    Last Post: - 13th November 2006, 03:20
