Shiftout over I2C possible?
Results 1 to 4 of 4
    Default Shiftout over I2C possible?
    Hello.
    I have PCF8574 I2C extender.
    I want to connect to it's outputs APA102 LED (which is SPI)
    Can PBP handle this, or I'll have to do manual bit forming over I2C bus, to have "proper" SPI at it's output pins?
    Default Re: Shiftout over I2C possible?
    Won't all these slow down your data communication?
    Aug 2011
    Boy. that's an understatement!
    You'll have to do three I2C writes for each bit (set data, set clock high, set clock low).
    It'll be as slow as molasses, but it'll work (as long as the APA102 isn't finicky about the SPI timing)
    Obviously you can't use Shiftout to do it.
    Yes it will be slow, but I have no issues with that, since APA102 will be used for static lighting and updated maybe once per day...
  1. SHIFTOUT, I2C, 1-Wire on same pins, possible?
    Last Post: - 12th March 2022, 22:17
  2. 128bit Shiftout? how?
    By gtvmarty in forum mel PIC BASIC Pro
    Last Post: - 17th April 2009, 22:31
  3. Shiftout/in
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2007, 12:48
  4. Shiftout
    By moby in forum mel PIC BASIC Pro
    Last Post: - 17th August 2004, 22:19
  5. Shiftout
    By f6ggy in forum mel PIC BASIC Pro
    Last Post: - 7th October 2003, 09:19
