Does manual say anywhere that it won't ?
When manual says byte sized variables, it is implied 8 bits I guess.
So this IC can't be used with PBP ?
I cannot see how one can send only 7 bits when the integrated command is set to send 8 bits...
I think you have to make your own routine, maybe in assembly.
or convert the 7 bit address to an 8 bit address as i have explained multiple times in other postsI think you have to make your own routine, maybe in assembly.
just spotted this gem on the arduino forum
you need to know better than the AI in order to know that the solution offered by the AI is wrong
It makes perfectly sense!
One cannot blindly trust the machine. The replies depend very much on the prompt anyway. So, if you do not how to ask or what to ask, then you cannot expect magic to happen, right?
