Has anyone tried AI with PICBASIC - Page 3
+ Reply to Thread
Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 132
  1. #81
    Default Re: Has anyone tried AI with PICBASIC
    I don't see any issues with IC address - it is done according to datasheet.
    1. Write to Config register:
    – First byte: 0b10010000 (first 7-bit I2C address followed by a low R/W bit)
    – Second byte: 0b00000001 (points to Config register)
    – Third byte: 0b10000100 (MSB of the Config register to be written)
    – Fourth byte: 0b10000011 (LSB of the Config register to be written
    when has a 7 bit i2c slave address ever worked in pbp?
    Does manual say anywhere that it won't ?
  3. #83
    When manual says byte sized variables, it is implied 8 bits I guess.
    So this IC can't be used with PBP ?
  5. #85
    I cannot see how one can send only 7 bits when the integrated command is set to send 8 bits...
    I think you have to make your own routine, maybe in assembly.
    or convert the 7 bit address to an 8 bit address as i have explained multiple times in other posts
    just spotted this gem on the arduino forum
    you need to know better than the AI in order to know that the solution offered by the AI is wrong
    It makes perfectly sense!
    One cannot blindly trust the machine. The replies depend very much on the prompt anyway. So, if you do not how to ask or what to ask, then you cannot expect magic to happen, right?
    I would say, that for relatively simple coding routines, PBP knowledge of AI had been improved, but just when you ask something more complex, you'll get this:
    can you create picbasic pro code which will draw a circle on a LCD screen, which uses ST7920 controller?
    (I'm omitting some DEFINE's and other non-relevant stuff)
    ' Initialize LCDLCDINIT' Main program loopMain:    ' Clear display    LCDOUT $01    ' Set cursor to home    LCDOUT $02    ' Set display to graphics mode    LCDOUT $3F    ' Set start line to 0    LCDOUT $40    ' Set display start line    LCDOUT $C0    ' Draw circle    CIRCLE 64, 32, 20
  10. #90
    It makes very human-like errors.
    For example, I asked it how to convert the time from GPS receiver, which simply outputs digits in ASCII format to raw decimal digits, and here's the code:
    hours = (time_data[0] - "0") * 10 + (time_data[1] - "0")minutes = (time_data[2] - "0") * 10 + (time_data[3] - "0")
    It assumed that "0" is the raw value of ASCII digit "0" In ZX Spectrum Basic it would be VAL("0"), but in PBP there's not VAL...
    Interesting, is there any other syntax of basic, which treats "0" as it's decimal value in ASCII table?
  11. #91
    Minus "0" means in fact -48.
    Maybe this is what is needed by the rest of the program. With just this line I am not sure if it is right or wrong.
    As always, answer depends on the prompt. If you give enough and precise info you will get better response.
    yes sure, I changed "0" to 48 and everything works fine.
    The question is, from where it took "0", is there any programming language that can make ASCII to decimal conversion that way?
  13. #93
    In every language "0" is equal to 48 dec. or "1" equal to 49, etc.
    What do you mean you changed "0" to 48 and it worked? I'm sure it worked fine with "0".
    You must stop mixing up the interpreted ZX BASIC with PBP.
    In PBP lingo
    48
    $30
    %00110000
    "0"
    are all representing the exact same thing, just differently for human readability.
    If you were to connect to 8 LEDs to PortB of your PIC and then do PortB = x where x is any of the above they would all result in the exact same thing being displayed on the LEDs.
    So, in your specific example subtracting "0" will subtract the numeric value 48 from the numeric value of the ASCII code for the digit question. This will result a numeric value equal to that of 'the digit'.
  15. #95
    nearly all can do that, except that in C,C++ etc it would be '0' not "0" [single quotes is a chr 'literal' double quote is a null terminated "string" c-str]
    I'm not mixing, but with PBP
    X-"0" gives syntax error while compiling.
  17. #97
    I am pretty sure it does not. Compiles just fine because "0" is in fact 48. So if X-48 compiles it will also compile X-"0".
    If course to have correct results you should not mix 0 (zero) with O (capital letter O) because they have different ascii value. But all compile fine.
    Mar 2005
    Cocoa, Florida
    I've found CoPilot to be OK for .net, but useless for PBP.
    ChatGPT can be helpful, but only when used sparingly - "Write me an I2C routine to read a [chip number]".
    AI has improved over the last couple of years.
  19. #99
    Yes, there are definitely some improvements with ChatGPT when it comes to PBP, but still a long way to go.
    Very often it has issues with syntax - it confuses PBP with Bascom or GC basic and uses operators from there.
    And when you ask it to check and correct, it says - "oh, you're right, this particular statement is not supported by PBP, let me modify a code for you".
    So while mostly being useless for PBP, at least it gives some direction, when I need to interface with some "fresh" hardware - syntax is usually wrong, and boundaries are not checked and code sequence is also messed, but registers/addresses usually are correct.
  20. #100
    DeepSeek is much better in creating programs.
    Not for a finished job of course, but helps to start.
    Well, I asked both to create a simple code - Read time from DS3231 and display it on HD44780 display.
    Judge by yourself
    ' PICBasic Pro Code to Read DS3231 RTC and Display Time on LCD
    ' Connections:
    ' - DS3231: SDA -> PORTC.4, SCL -> PORTC.3
    ' - LCD: Connected in 4-bit mode to PORTB
    ' Define LCD
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 3
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    ' I2C Pin Assignments
    SDA VAR PORTC.4
    SCL VAR PORTC.3
    ' Time Variables
    second VAR BYTE
    minute VAR BYTE
    hour   VAR BYTE
    ' DS3231 I2C Address
    RTC_ADDR CON $D0  ' 7-bit address shifted left
    ' Convert BCD to Decimal
    FUNC_BCD2DEC:
        MOVF  second, W
        ANDLW  0x0F
        MOVWF _temp1
        SWAPF second, W
        ANDLW  0x0F
        MOVWF _temp2
        MOVF  _temp2, W
        MOVWF second
        ADDWF _temp1, F
        MOVF  minute, W
        ANDLW  0x0F
        MOVWF _temp1
        SWAPF minute, W
        ANDLW  0x0F
        MOVWF _temp2
        MOVF  _temp2, W
        MOVWF minute
        ADDWF _temp1, F
        MOVF  hour, W
        ANDLW  0x0F
        MOVWF _temp1
        SWAPF hour, W
        ANDLW  0x0F
        MOVWF _temp2
        MOVF  _temp2, W
        MOVWF hour
        ADDWF _temp1, F
    ' Read Time from DS3231
    Read_Time:
        I2CWRITE SDA, SCL, RTC_ADDR, 0, [0]  ' Set register pointer to 0
        I2CREAD SDA, SCL, RTC_ADDR, [second, minute, hour] ' Read time
        GOSUB FUNC_BCD2DEC  ' Convert BCD to decimal
    ' Initialize LCD
    PAUSE 500
    LCDOUT $FE, 1 ' Clear LCD
    LCDOUT $FE, $80, "Time: "
    ' Main Loop
        GOSUB Read_Time  ' Read DS3231 time
        LCDOUT $FE, $C0, DEC2 hour, ":", DEC2 minute, ":", DEC2 second ' Display time
        PAUSE 1000  ' Wait 1 second
    GOTO Main
    ' PICBASIC PRO code to read time from DS3231 and display on HD44780 LCD
    ' Define PIC microcontroller (e.g., PIC16F877A)
        __CONFIG _HS_OSC & _WDT_OFF & _PWRTE_ON & _LVP_OFF
    ' Define LCD pins
    DEFINE LCD_DREG PORTD   ' LCD data port
    DEFINE LCD_DBIT 4       ' Starting data bit (D4)
    DEFINE LCD_RSREG PORTE  ' RS pin port
    DEFINE LCD_RSBIT 0      ' RS pin bit
    DEFINE LCD_EREG PORTE   ' Enable pin port
    DEFINE LCD_EBIT 1       ' Enable pin bit
    ' Define I2C pins
    DEFINE I2C_SCL PORTB, 1 ' SCL pin (RB1)
    DEFINE I2C_SDA PORTB, 2 ' SDA pin (RB2)
    ' Include necessary libraries
    INCLUDE "DS3231.bas"    ' DS3231 I2C RTC library
    INCLUDE "LCD.bas"       ' HD44780 LCD library
    ' Variables
    Dim second As Byte
    Dim minute As Byte
    Dim hour As Byte
    Dim day As Byte
    Dim month As Byte
    Dim year As Byte
    ' Initialize LCD
    LCDOUT $FE, $01  ' Clear LCD
    LCDOUT $FE, $0C  ' Turn on display, no cursor
    ' Main loop
        ' Read time from DS3231
        DS3231_ReadTime hour, minute, second
        ' Display time on LCD
        LCDOUT $FE, $80, "Time: ", DEC2 hour, ":", DEC2 minute, ":", DEC2 second
        ' Wait for 1 second
        PAUSE 1000
        ' Repeat
        GOTO Main
  22. #102
    which one is which
    It is important to know also the prompt given since it plays crucial role for the result.
    On deepseek, and on my second attempt, I had to ask for the correct syntax regarding variables and config settings. So that time it got it correct while ChatGPD had really difficulties correcting the errors.
    But asking for Tiananmen Square was a failure!
    It does not matter, since none of code works.
    Sometimes ChatGPT makes really funny moves - Once it created a new type of variable - "svar" which is not in PBP, I asked, what is this - so it replied, "Yes, this is a new type of variable, I've invented it for convience", "but such variable is not supported by picbasic pro?", "Yes I know, this is very sad, below is the code which works without svar variable" (and that code was not compiling anyways).
  25. #105
    Here's a working code, written by ChatGPT, which allows to control playback of DY-SV17F and similar "DY" series mp3 modules. These modules provide far better audio quality, no noise and cracking, compared to more common, "Dfplayer" type of modules, and also, they have 4mb of onboard flash (and also MicroSD and USB flash support), which is quite handy, when you need to design an announcement or counter system.
    This code took multiple iterations - it was not compiling initially because it used Proton Basic statements randomly. It was figured out. Code compiled, but not working. After reading the datasheet, I've figured out that it was not sending "source selection" statement. After pointing it to that, it took about 20 minutes to generate the code. It was still far from perfect, because "main" part was at the bottom, so module was confused. Now I've moved manually the "Main" code to the proper place and yay, it works!
    The moral of story? - It coded a lot of code, which most likely I would never be able to write, considering my limited skills, but until I suggested what is wrong and needs to be fixed, it was struggling with the working code, despite making several attempts.
    ' Use software UART on a chosen pin
    MP3_TX   VAR PORTB.1     ' pick your PIC output pin
    BAUD9600 CON 84          ' 9600 baud, N,8,1 for SEROUT2
    ' === Constants from DY-SV17F datasheet ===
    USB     CON $00
    TF_CARD CON $01
    FLASH   CON $02
    ' Command IDs
    CMD_PLAY          CON $02
    CMD_PAUSE         CON $03
    CMD_STOP          CON $04
    CMD_PREV          CON $05
    CMD_NEXT          CON $06
    CMD_PLAY_SPECIFIC CON $07
    CMD_SWITCH_DEVICE CON $0B
    CMD_VOL_SET       CON $13
    ' === Variables ===
    dyCmd    VAR BYTE
    dyLen    VAR BYTE
    dyBuf    VAR BYTE[8]
    i        VAR BYTE
    sumW     VAR WORD
    crc      VAR BYTE
    track    VAR WORD
    hiB      VAR BYTE
    loB      VAR BYTE
    vol      VAR BYTE
    ' --- Example main ---
        PAUSE 500
        GOSUB DY_SelectDeviceFlash      ' set source = FLASH
        vol = 20
        GOSUB DY_SetVolume
        track = 1
        GOSUB DY_PlayTrack
        PAUSE 5000
        GOSUB DY_Pause
        PAUSE 1500
        GOSUB DY_Play
        PAUSE 3000
        GOSUB DY_Stop
    ' --- Low-level: send DY-SV17F packet (AA, cmd, len, data..., crc) ---
    DY_Send:
        sumW = 0
        SEROUT2 MP3_TX, BAUD9600, [$AA]
        sumW = sumW + $AA
        SEROUT2 MP3_TX, BAUD9600, [dyCmd]
        sumW = sumW + dyCmd
        SEROUT2 MP3_TX, BAUD9600, [dyLen]
        sumW = sumW + dyLen
        IF dyLen > 0 THEN
            FOR i = 0 TO dyLen-1
                SEROUT2 MP3_TX, BAUD9600, [dyBuf[i]]
                sumW = sumW + dyBuf[i]
            NEXT
        crc = sumW & $FF
        SEROUT2 MP3_TX, BAUD9600, [crc]
        PAUSE 10
    ' --- High-level helpers ---
    DY_SelectDeviceFlash:              ' Switch to internal FLASH (02)
        dyCmd = CMD_SWITCH_DEVICE
        dyLen = 1
        dyBuf[0] = FLASH
        GOSUB DY_Send
        PAUSE 150                       ' module auto-plays first track after switch
        ' Stop playback immediately so only source is selected:
        dyCmd = CMD_STOP
        dyLen = 0
        GOSUB DY_Send
    DY_Play:
        dyCmd = CMD_PLAY : dyLen = 0
        GOSUB DY_Send
    DY_Pause:
        dyCmd = CMD_PAUSE : dyLen = 0
        GOSUB DY_Send
    DY_Stop:
        dyCmd = CMD_STOP : dyLen = 0
        GOSUB DY_Send
    DY_Next:
        dyCmd = CMD_NEXT : dyLen = 0
        GOSUB DY_Send
    DY_Prev:
        dyCmd = CMD_PREV : dyLen = 0
        GOSUB DY_Send
    DY_SetVolume:                       ' vol = 0..30
        dyCmd = CMD_VOL_SET
        dyLen = 1
        dyBuf[0] = vol
        GOSUB DY_Send
    DY_PlayTrack:                       ' track = 1..65535
        hiB = track >> 8
        loB = track & $FF
        dyCmd = CMD_PLAY_SPECIFIC
        dyLen = 2
        dyBuf[0] = hiB
        dyBuf[1] = loB
        GOSUB DY_Send
    Despite the progress of AI it is evident that will not replace soon a programmer.
    And for the size of projects like the one you showed, probably it is worth the time to do it yourself and expand your experience than spend time in showing AI how to do it!
    My 2c.
  27. #107
    Aug 2011
    You could save some code by replacing 'sumW' with 'crc'
  28. #108
    Well, your approach is different. I'm taking the practical route.
    For example, there's an artist, who made nice clay sculpture and wants to install led light strip inside it and configure it in the way, that say, first 5 leds are green, next 10 are cyan, next 15 are red and all these slowly fade in and out. He should learn programming for that?
    Nope. He'll go, buy arduino, led strip, wire them together (there's just 3 wires to be wired) and will ask AI to generate the code according to his description. So within no time, he'll have functioning device, without learning what is FIFO, ALU, DWORD vs BIT type variable and many, many unnecessary things.
  29. #109
    Aug 2011
    Except when it doesn't work and they don't have the foggiest idea how to fix it.
    What's worse is I see folks using AI to write code for products they sell. You should be required to label your products with this so we know what products to avoid.
  30. #110
    Mar 2005
    Cocoa, Florida
    I've been playing with OpenAI and Copilot for a while now, and my experience is that they are better at higher-level syntax languages than the curly-bracket department. That means better at Python/VB than C#, better at Swift than Objective C, and better at PICBasic than Microchip C.
    My main use is Copilot in Visual Studio. Copilot is an idiot savant. Although it makes stupid mistakes, it is unbelievably productive, allowing me to churn out a week's work in a day. While code completion is much better than the old vanilla Intellisense, it's the Copilot Chat that really shines.
    It's a powerful tool, use carefully.
  31. #111
    So, speaking simply, AI is becoming an everyday object, and many skills will be not needed. For example, many of you know how to sharpen goose feather for ink writing? Or many of you can start fire with sticks? These "skills" are quite obsolete now, but say, 200 years ago, these were mandatory. So same with AI - it will take handle of a lot of tasks, which previously were human-only prerogative.
  32. #112
    Miami, Florida USA
    My 2c.
    I agree with you. A friend of mine challenged me that he could write any code for any project I wanted with AI. I think he fails to understand that writing code involves a lot of troubleshooting and problem solving. I don't think that we are there yet with AI.
    Anonymous
  33. #113
    you will be able to detect when AI is "ready",
    it will cost an arm and a leg to use it
    Another example when AI code works on PBP - Multiple ADC button reading and debouncing:
    ReadButton:
        TempE = 0
        ' Repeat check 5 times for debounce
        For cnter = 1 to 5
            ADCIN 0, adcval        ' Read from AN0 (adjust channel if needed)
            If (adcval >= 230) And (adcval <= 270) Then
                TempE = 1
            ElseIf (adcval >= 290) And (adcval <= 330) Then
                TempE = 2
            ElseIf (adcval >= 380) And (adcval <= 440) Then
                TempE = 3
            ElseIf (adcval >= 580) And (adcval <= 700) Then
                TempE = 4
            Else
                TempE = 0
            EndIf
            ' If reading doesn’t match previous stable result, reset debounce
            If cnter = 1 Then
                E = TempE
            Else
                If TempE <> E Then
                    E = 0
                EndIf
            EndIf
            Pause 10    ' small delay between samples
        Next cnter
    However, it still needed tweaking, because it used counter as variable name, which is reserved word, so I've changed it to cnter and this code works and far more efficient than my own - shown below:
    keyhandler:
    babo:
    adcin 0,adcval
    if adcval<100 then goto resetvar 'reset internal debounce variables
    if adcval>230 and adcval<270 then a=a+1
    if adcval>290 and adcval<340 then b=b+1
    if adcval>385 and adcval<440 then c=c+1
    if adcval>570 and adcval<660 then d=d+1
    cnter=cnter+1 'increase loop iteration counter
    if cnter=100 then goto analyzer 'if enough time pressed, go to analyzer
    goto babo
    Analyzer:
    ' --- Comparison Logic ---
    IF (A = B) OR (A = C) OR (A = D) OR (B = C) OR (B = D) OR (C = D) THEN
        E = 5                              ' Tie detected
        IF (A > B) AND (A > C) AND (A > D) THEN
            E = 1                          ' A is greatest
        ELSEIF (B > A) AND (B > C) AND (B > D) THEN
            E = 2                          ' B is greatest
        ELSEIF (C > A) AND (C > B) AND (C > D) THEN
            E = 3                          ' C is greatest
        ELSEIF (D > A) AND (D > B) AND (D > C) THEN
            E = 4                          ' D is greatest
            E = 5                          ' Safety fallback (should not reach here)
    resetvar:
    cnter=0
    'a=0
    b=0
    c=0
    d=0
    I think the part of if-then block can be faster with smaller code size like this:
    If adcval<230 then TempE=0
    if adcval >= 230 Then TempE = 1
    If adcval >= 290 Then TempE = 2
    If adcval >= 380 Then TempE = 3
    If adcval >= 580 ThenTempE = 4
    if adcval > 700 then  TempE = 0
    But since there will be quantisizing error and the adcval may play at least one bit, this will fail most of the time:
            If cnter = 1 Then
                E = TempE
            Else
                If TempE <> E Then
                    E = 0
    this part should allow a margin of at least 2 digit play for adcval.
    Miami, Florida USA
    True. Unless they have open source code like in Github. I think that eventually we will get there, but we are not there yet. Maybe the new "programmer" in the future will be the professional that can ask AI how to write very complex programming code for a complex project.
    Anonymous
  37. #117
    There are some open source AI projects, like Fooocus already. You can download and run them locally, without internet.
  38. #118
    AI is just unregulated theft of intellectual property with no payment for or even acknowledgement of the source.[programming is IP and an art form too]
    The AI generated result is used with no consequences for its impact and no need to even identify that it was AI generated. A brave new world
    Very true.
    My other job has to do with book publishing. Many well known publishers have sued the AI companies for this exact theft. Serious problems have risen in every aspect of intellectual property (writing, programming, art designing etc).
    and that is funny thing.
    Human can learn from other works and create his art, literature or music based on that - this is fine. But same not fine for AI?
  1. conversion from picbasic to picbasic pro
    By winjohan in forum mel PIC BASIC Pro
    Last Post: - 1st November 2011, 19:00
  2. Proton PICBASIC vs MeLabs PICBASIC
    By Fredrick in forum General
    Last Post: - 11th January 2008, 22:51
  3. PICBasic Pro vs Proton PICBasic
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2006, 17:11
  4. picbasic 2.46
    By jojokatada in forum mel PIC BASIC Pro
    Last Post: - 29th April 2005, 04:34
  5. PicBasic Pro & PicBasic syntax different
    By Billyc in forum General
    Last Post: - 16th April 2004, 22:19
