RF Transmitter
Results 1 to 5 of 5
Thread: RF Transmitter
    Look at an earlier post of mine: http://www.picbasic.co.uk/forum/show...79&postcount=6
    et_Fong's Avatar
    et_Fong Guest
    since i am using Microsoft VB to make my interface, so i am using "170" as synchronize signal, "0" as address bit, "0~9" data bit which run certain function. that's why i need to perform the "match" , to read the "0" address bit, which is similar as connect PORT B to ground.
    after i send the RF signal, the receiver size will receive and decode the signal to 4 parallel data to PIC16F84A RA0~3, then it will control the movement according to the data receive........
  1. Control NEXA 230V RF Switch
    By Fredrick in forum Code Examples
    Last Post: - 7th December 2009, 00:19
  2. Interfacing 16F88 to RF module
    By scomi85 in forum General
    Last Post: - 19th February 2009, 13:52
  3. problem with sending data using RF module
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2008, 18:08
  4. Interfacting RF Module
    By rastan in forum General
    Last Post: - 10th November 2004, 23:27
  5. RF transmitter, RS232, and Visual Basic
    By pt3rg in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2004, 20:42
