Installation sequence
Results 1 to 24 of 24
    Hi Robert,
    CONFIG PLLDIV = 5 is a "config word" option. This sets the PLL prescaler to
    divide the 20MHz primary osc input by 5. This is required when using a 20MHz
    primary osc because the input to the 96MHz PLL must always be 4MHz.
    DEFINE OSC 20 is different. This is used internally by PBP to adjust timing of
    PBP library routines to the 20MHz primary oscillator.
    bioeng-mostafa,
    If you don't have the 18F4550 device header files, then you need to update
    to the latest version of PBP. Version 2.46 introduced support for the 18F4550
    series.
    Just having someone email you device header files does not guarantee you'll
    be able to use the new device. There are more to some PBP updates than
    additional device specific header files.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    bioeng-mostafa's Avatar
    bioeng-mostafa Guest
    hello
    plase any one have PBP Version 2.46 introduced support for the 18F4550
    send it to me or tell me how i can get it
    Default help for pic18f4550
    hello
    my mail is removed
    thank you
    bioeng-mostafa
    Please don't ask for people to make and send you Pirate copies, get your own legally like the rest of us have had to.
    If you need an upgrade, go back to your original supplier or MeLabs directly.
  1. How to set sequence of interrupt for PIC
    Last Post: - 21st June 2008, 12:17
  2. Replies: 1
    Last Post: - 23rd December 2006, 14:29
  3. ic prog installation
    By sakthi in forum mel PIC BASIC Pro
    Last Post: - 15th November 2006, 15:01
  4. FOR sequence is skipped
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 10th August 2006, 03:35
  5. Replies: 0
    Last Post: - 26th March 2006, 02:13
