Installation sequence
Results 1 to 24 of 24
    Well, found the answer to some problems myself. I editted the pathnames in the includes and libs and things work further (added disk and full pathname).
    I'm still faced by that deprecate warning, still no idea how to get rid of that.
    And then there is one last ERROR[118]: OVERWRITING PREVIOUS ADDRESS at line 50 of the ASM file to figure out.
    Look at that !
    http://www.picbasic.co.uk/forum/show...87&postcount=6
    for the over writre blah blah just comment the default config fuses in the .INC file in the PBP folder
    Ok, this is funky. The 1st thing I did was to go look in the FAQ for help on these issues and I only had 2 threads listed. I just did a SEARCH through the forum and found this thread:
    Presetting Configuration Fuses (PIC Defines) into your Program
    But if I go look in FAQ again, it's not there, always the same two threads? Anyways, Mister_E posted the answer to why I get the OVERWITE message.
    Now if I can just find the answer to those pesky DEPRECATE warnings.
    Thanks Steve.
    (don't you hate posting at the same time as someone else?)
    P.S.: STEVE, GET YOURSELF A HOTMAIL ACCOUNT AND EMAIL ME.
    Mr Demon.. open your eyes i already post a link above ;o)
    EDIT: Glad to see you found it! I already have an hotmail account... without ANY KIND OF easy to hack Messenger or whatsoever. Videotron is working now..!
    Steve, like this? I kept all the values so it is easier to change them around later.
    If this is correct, it would make a good addition to one of those Configuration threads in the FAQ.
    Steve, I must have something wrong in the config switches above. The LED is blinking more than twice as fast as it should. This is the test code:
    'define LOADER_USED 1
    LED1 VAR PortD.1
    START: HIGH LED1
    PAUSE 1000
    LOW LED1
    PAUSE 1000
    GOTO START
    Finish: end
    I am using a 20MHz external oscillator. I would like to be able to use slow speed USB on this device later. Do you see something I missed in the config?
    you just need to modify the .INC in the PBP folders. My own file looks like that
    ;*  18F4550.INC                                                 *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2004 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 12/31/04                                        *
    ;*  Version   : 2.46                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
            LIST p = 18F4550, r = dec, w = -311, f = inhx32
            INCLUDE "P18F4550.INC"	; MPASM  Header
           ; __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
           ; __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
           ; __CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
           ; __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
           ; __CONFIG    _CONFIG4L, _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L
            NOLIST
            LIST
    EEPROM_START	EQU	0F00000h
    BLOCK_SIZE	EQU	32
    not much.. it's the whole file i have.
    Do you still use the Bootloader? Did you also use the DEFINE OSC 20?
    How about your current one?
    Quote Originally Posted by mister_e
    You can't just comment out default values. You must assign them something, somewhere, no?
    Nope.
    Nope.
    This is my latest code, same acceleration problem:
    LED1 VAR PortD.1
    START: HIGH LED1
    PAUSE 1000
    LOW LED1
    PAUSE 1000
    GOTO START
    Finish: end
    And these are the configuration bits used:
    ; 96MHz PLL Prescaler:
    CONFIG PLLDIV = 5 ;Divide by 5 (20MHz input)
    ; CPU System Clock Postscaler:
    CONFIG CPUDIV = OSC1_PLL2 ;[OSC1/OSC2 Src: /1][96MHz PLL Src: /2]
    ; Full-Speed USB Clock Source Selection:
    CONFIG USBDIV = 1 ;Clock source from OSC1/OSC2
    ; Oscillator Selection bits:
    CONFIG FOSC = HS ;HS oscillator, HS used by USB
    ; Fail Safe Clock Monitor:
    CONFIG FCMEM = OFF ;Disabled
    ; Internal/External Switch Over:
    CONFIG IESO = OFF ;Disabled
    ; Power Up Timer:
    CONFIG PWRT = ON ;Enabled
    ; Brown Out Reset:
    CONFIG BOR = ON ;Enabled, SBOREN bit is disabled
    ; Brown Out Voltage:
    CONFIG BORV = 21 ;2.1V
    ; USB Voltage Regulator Enable:
    CONFIG VREGEN = OFF ;Disabled
    ; Watchdog Timer:
    CONFIG WDT = OFF ;HW Disabled - SW Controlled
    ; Watchdog Postscaler:
    CONFIG WDTPS = 32768 ;1:32768
    ; MCLR Enable:
    CONFIG MCLRE = ON ;Enabled
    ; Low Power Timer1 Oscillator Enable:
    CONFIG LPT1OSC = OFF ;Timer1 oscillator configured for high power
    ; Port B A/D Enable:
    CONFIG PBADEN = OFF ;PortB<4:0> pins are configured as digital I/O on RESET
    ; CCP2 Mux bit:
    CONFIG CCP2MX = ON ;CCP2 input/output is multiplexed with RC1
    ; Stack Overflow Reset:
    CONFIG STVREN = ON ;Enabled
    ; Low Voltage ICSP:
    CONFIG LVP = OFF ;Disabled
    ; Dedicated In-Circuit Debug/Programming Enable:
    CONFIG ICPRT = OFF ;Disabled
    ; Extended Instruction Set Enable:
    CONFIG XINST = OFF ;Disabled
    ; Background Debugger Enable:
    CONFIG DEBUG = OFF ;Disabled
    ; Code Protection Block 0:
    CONFIG CP0 = OFF ;Disabled
    ; Code Protection Block 1:
    CONFIG CP1 = OFF ;Disabled
    ; Code Protection Block 2:
    CONFIG CP2 = OFF ;Disabled
    ; Code Protection Block 3:
    CONFIG CP3 = OFF ;Disabled
    ; Boot Block Code Protection:
    CONFIG CPB = OFF ;Disabled
    ; Data EEPROM Code Protection:
    CONFIG CPD = OFF ;Disabled
    ; Write Protection Block 0:
    CONFIG WRT0 = OFF ;Disabled
    ; Write Protection Block 1:
    CONFIG WRT1 = OFF ;Disabled
    ; Write Protection Block 2:
    CONFIG WRT2 = OFF ;Disabled
    ; Write Protection Block 3:
    CONFIG WRT3 = OFF ;Disabled
    ; Boot Block Write Protection:
    CONFIG WRTB = OFF ;Disabled
    ; Configuration Register Write Protection:
    CONFIG WRTC = OFF ;Disabled
    ; Data EEPROM Write Protection:
    CONFIG WRTD = OFF ;Disabled
    ; Table Read Protection Block 0:
    CONFIG EBTR0 = OFF ;Disabled
    ; Table Read Protection Block 1:
    CONFIG EBTR1 = OFF ;Disabled
    ; Table Read Protection Block 2:
    CONFIG EBTR2 = OFF ;Disabled
    ; Table Read Protection Block 3:
    CONFIG EBTR3 = OFF ;Disabled
    ; Boot Block Table Read Protection:
    CONFIG EBTRB = OFF ;Disabled
    I'm programming the chip via the MeLabs serial programmer.
  1. How to set sequence of interrupt for PIC
    Last Post: - 21st June 2008, 11:17
  2. Replies: 1
    Last Post: - 23rd December 2006, 13:29
  3. ic prog installation
    By sakthi in forum mel PIC BASIC Pro
    Last Post: - 15th November 2006, 14:01
  4. FOR sequence is skipped
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 10th August 2006, 02:35
  5. Replies: 0
    Last Post: - 26th March 2006, 00:13
