Ok, things are getting worse. I was just going down my checklist and reinstalling everything and I got a snag at update 2.46a. I get this error:
Cannot update version 2.46.
E:\PBP\INC\M16F684.INC: unknown version.
Any idea what's going on?
__CONFIG has been deprecated for PIC 18F devices. Use directive CONFIG.
According to dictionary.com that means __CONFIG is obsolete and now replaced by CONFIG. It's not just a matter of replacing the text, that didn't work. Is there new syntax? How would you write this statement now?
@ __CONFIG _CONFIG1H, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_1_1L
Jeez, now I have problems finding includes in MicroCode Studio. The file pathnames are not right...
Well, found the answer to some problems myself.I editted the pathnames in the includes and libs and things work further (added disk and full pathname).
I'm still faced by that deprecate warning, still no idea how to get rid of that.
And then there is one last ERROR[118]: OVERWRITING PREVIOUS ADDRESS at line 50 of the ASM file to figure out.
Look at that !
http://www.picbasic.co.uk/forum/show...87&postcount=6
for the over writre blah blah just comment the default config fuses in the .INC file in the PBP folder
Ok, this is funky. The 1st thing I did was to go look in the FAQ for help on these issues and I only had 2 threads listed. I just did a SEARCH through the forum and found this thread:
Presetting Configuration Fuses (PIC Defines) into your Program
But if I go look in FAQ again, it's not there, always the same two threads? Anyways, Mister_E posted the answer to why I get the OVERWITE message.
Now if I can just find the answer to those pesky DEPRECATE warnings.
Thanks Steve.
(don't you hate posting at the same time as someone else?)
P.S.: STEVE, GET YOURSELF A HOTMAIL ACCOUNT AND EMAIL ME.
Mr Demon.. open your eyes i already post a link above ;o)
EDIT: Glad to see you found it! I already have an hotmail account... without ANY KIND OF easy to hack Messenger or whatsoever. Videotron is working now..!
Steve, like this? I kept all the values so it is easier to change them around later.
If this is correct, it would make a good addition to one of those Configuration threads in the FAQ.
