433 Mhz Data Receiver
Results 1 to 15 of 15
    Default Manchester
    Hi People,
    i have a question ,can I use this manchester code like in this example.
    Trough PortA.0 is incoming encoded data from my transmitter and is then decoded and trough PortA.1 is going encoded data out.
    Define LOADER_USED 1
    Include "modedefs.bas" ' Mode definitions for Serout
    ADCON1=7
    define osc 4
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_SPBRG 207 ' 1200 Bauds
    DEFINE HSER_CLOERR 1
    n var byte
    d var byte
    myVar VAR byte
    CounterA var Byte
    ErrorFlag var Bit
    MyData var Byte
    encoded var Word
    v var word
    pause 10 ' safe start-up delay
    serin porta.0,N1200,v
    ErrorFlag=0
    For CounterA=0 to 7
    If v.1=0 then
    MyData.7=0
    If v.0=0 then ErrorFlag=1
    MyData.7=1
    If v.0=1 then ErrorFlag=1
    v=v>>2
    If CounterA<7 then MyData=MyData>1
    next
    goto encodemanchester
    encodeManchester:
    For d=0 TO 7
    IF mydata.0[d]=0 Then
    encoded.0[d*2]=0
    encoded.0[d*2+1]=1
    Else
    encoded.0[d*2]=1
    encoded.0[d*2+1]=0
    EndIF
    serout porta.1,N1200,[encoded]
    hserout [encoded]
    Next
    Please for help,thanks very much.
    Pesti.
    Is nobody here that can help me please?
    Regard Pesti.
    Default 433 MHz receiver
    The serin command is used as folow:
    Transmitter code: SerOut GPIO.1,N1200,["A","work"]
    Receiver code: SerIn porta.3,N1200,["A"],B0,B1,B2,B3 received data will be: B0=w, B1=o, B2=r, B3=k
    Note the N1200 is the baud rate, that is very important the N can be replaced with a T depending on the polarity of the data you receive, then the ["A"] the program will wait on the pin porta.3 until it receive an "A" then it will read the data that follow into the 4 variables B0-B3, you can use more variables if you want to.
    But if your transmitter is using a decoder chip it is impossible to read the data you will always get garbage and not real data.
    The data that you receive while the transmitter is off is only garbage or QRM caused by florescent light or other interference.
    To sum up, you will need to know at what baud rate and polarity your transmitter is sending the data and you need to know what the [qualifier] is, it can be any character/s.
    You can't teach an old dog new tricks, but I'm always willing to try.
    Post 433 Mhz Data Receiver
    You can try the following:
    Create some word long variables eg
    B0 var WORD
    B1 var WORD
    B2 var WORD
    B3 var WORD
    SerIn porta.3, N1200,,, B0, B1, B2, B3
    then compare the variables if it contain the same data then it will be the correct code because the encoder/decoder chips send out a 12 bit data that will fit into a word variable that can take up to 16 bits of data
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
