how to use GLCD with picbasic pro
Results 1 to 14 of 14
    Apr 2006
    Smile Graphics LCD with different resolutions?
    Hi all,just want to know whether the pic basic pro program can be use to
    program a higher resolution like 320 X 240 Dots LCD Module instead of just
    the standard 128 X 64 Dots GLCD module?If no then is there any other way
    to drive /program those high resolution GLCD?
    Thanks.
    Quote Originally Posted by mesamune80 View Post
    Thanks.
    And yet again, PBP does not have native high level graphic LCD support.
    There's too many types/standard/methods to operate them to combine them all into one inclusive package.
    If you're looking for the easy route, here's something you may want to take
    a look at.
    Just received a few samples of these from the mfg for evaluation.
    http://www.dontronics-shop.com/home.php?cat=371
    I was very impressed when I fired one up. A single I/O-pin is all you need.
    It's like adding a small full-color LCD TV to your project, and controlling it
    with simple serial commands.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Looks impressive indeed! Something to add in my next 'new toy' order i guess.
    Thanks Bruce!
    a look at.
    I'm tellin' ya, between this and mister_e USB example, I just might be single again by the end of the year! either that or broke...or maybe both!
  1. ICD, ICSP and Picbasic Pro
    By mwhatley in forum mel PIC BASIC Pro
    Last Post: - 8th August 2024, 21:42
  2. VB.net and Picbasic Pro
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 15th November 2007, 21:18
  4. Question for all that use MELABS PICBASIC PRO
    By oskuro in forum Off Topic
    Last Post: - 24th March 2005, 18:15
  5. PicBasic Pro & PicBasic syntax different
    By Billyc in forum General
    Last Post: - 16th April 2004, 22:19
