arrays LEDs Switches
Results 1 to 3 of 3
    ilteris's Avatar
    ilteris Guest
    Default arrays LEDs Switches
    Hello Folks,
    I am trying to control these tiny LEDs with my switches, right now 8 for 8 but it is going to be 25 for 25 in the end so this is just a proto to figure out whats going on. MY code is working in a sense, I just happen to get high all of my LEDs like I wanted and made some low according to me, but when I try to connect them to my switches which are lying on the PORTB, I just could control the PINO of the PORTB, I am pasting my code below, and looking for your answers.
    Thanks in advance
    ilteris.
       define OSC 4
       start:
       TRISC = 0
       TRISB = 1
       PORTC = 255
       PORTB = 255
       i var BYTE
       j var BYTE
       myByte var BYTE
       delayTime var Byte
       mySwitch var  byte
       delayTime = 100
       pause delayTime
      for j=0 to 7
      if PORTB.0(j) = 1 then
           mybyte.0(j) = 0
             PORTC = myByte
       mybyte.0(j) = 1
          PORTC = myByte
            next
         for i=0 to 7
            if i = 4 then
       myByte.0(i) = 0
              PORTC = myByte
       myByte.0(i) = 1
       PORTC = myByte
       next
    You are only setting Bit 0 of PortB to input... Try this...
    	TRISB=%11111111
    	TRISC=%00000000
    	Option_Reg.7=0
    	Mybyte var Byte
    Loop:
    	MyByte=PortB
    	PortC=Mybyte
    	Pause 100
    	Goto Loop
    ilteris's Avatar
    ilteris Guest
    hello Melanie,
    Thanks for the quick feedback although I am not sure I understood it correctly, I try adding this snippet to my with no dice, also open a new file and tried in that too but it is still no go, can you elaborate it quite a bit, also I couldnt find any documents on option_reg, can you tell me what is it?
    Thank you so much for your patience.
    ilteris.
  1. Run a string of LEDs from the mains
    Last Post: - 1st October 2009, 18:55
  2. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
  3. switches & LEDs ... my first attempt
    By yankee in forum mel PIC BASIC Pro
    Last Post: - 28th January 2006, 12:51
  4. controlling leds with the switches
    By ilteris in forum mel PIC BASIC Pro
    Last Post: - 12th October 2005, 21:02
  5. Replies: 5
    Last Post: - 16th February 2005, 11:57
