Thanks a mill but actually I did
same problem but in a different way: please view attachment
hrifai
hrifai
mmm, usually PBP should be installed as close to the hard-drive root as possible I.E C:\PBP
I think that if the path+filename string size is the main cause. What about if you change to 16F88? about 16F84A?
Go to HELP...ABOUT what version of PBP is it showing? Have you multiple PBP installations on your hard drive? If so, try selecting VIEW...COMPILE AND PROGRAM options and point it towards the correct version of PBP.
Thank You all
The problem was solved after reinstalling all needed applications directly on the C: drive
I am sorry for the way I was rushing for a reply, but it is a matter of futur to me
Thank you again
