Target Processor
Results 1 to 9 of 9
    hrifai's Avatar
    hrifai Guest
    Default Irrelavant
    I guess it is Irrelavant because even I am using examples without any addition it is the same thing. it seems to be a missing include or something.
    But here is a simple one :
    Pause 500 ' Wait for LCD to startup
    loop:
    Lcdout $fe, 1 ' Clear LCD screen
    Lcdout "Hello" ' Display Hello
    Pause 500 ' Wait .5 second
    Lcdout "World"
    Goto loop ' Do it forever
    mmm no problems here... well the only thing i can suggest is to remove your PBP installation and reinstall it again.
    Sorry i can't say more than that
    hrifai's Avatar
    hrifai Guest
    Default Thanks a mill
    Thanks a mill but actually I did
    same problem but in a different way: please view attachment
    hrifai
    mmm, usually PBP should be installed as close to the hard-drive root as possible I.E C:\PBP
    I think that if the path+filename string size is the main cause. What about if you change to 16F88? about 16F84A?
    Feb 2005
    Saltburn by the Sea
    Go to HELP...ABOUT what version of PBP is it showing? Have you multiple PBP installations on your hard drive? If so, try selecting VIEW...COMPILE AND PROGRAM options and point it towards the correct version of PBP.
    hrifai's Avatar
    hrifai Guest
    Default Problem solved
    Thank You all
    The problem was solved after reinstalling all needed applications directly on the C: drive
    I am sorry for the way I was rushing for a reply, but it is a matter of futur to me
    Thank you again
  1. MicroCode Studio and Target Processor
    By NOJPIC in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2010, 18:40
  2. Cant change target processor to compile
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 9th November 2009, 18:31
  3. 18F4685 not in target processor list
    Last Post: - 15th July 2007, 13:13
  4. Default target processor
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 28th June 2007, 00:20
  5. Target Processor not in list?
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 13th November 2005, 19:35
