MCP23016 I/O expander
Results 1 to 40 of 43
    Feb 2004
    Germany
    Quote Originally Posted by Demon
    Ok, I'm trying to read from the 2nd MCP23016 and it's not working smoothly. I display the word on an LCD, and bits seem to flicker sometimes. When I press a button, the corresponding bit turns on, but there are some 'free games' here and there.
    Robert,
    we don't want to guess anymore, please post your full code and schematic.
    regards
    Ralph
    'define LOADER_USED 1
    ADCON1 = 7 ' A/D off, all digital
    @ DEVICE PIC16F877, HS_OSC, WDT_OFF, PWRT_ON, BOD_ON, LVP_OFF, CPD_OFF, WRT_OFF, DEBUG_OFF, PROTECT_OFF
    define OSC 20
    DEFINE LCD_DREG PORTA
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 4
    define LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    DEFINE I2C_SLOW 1
    DEFINE I2C_HOLD 1
    I2CSCL VAR PortD.1
    SDAISW1 VAR PortC.2
    LOCGPIO CON $00
    LOWWORD CON %0000000000000000
    I2CCTRL VAR BYTE
    I2CLOCB VAR BYTE
    I2CWORD VAR WORD
    CTRLIOW CON %01000000
    CTRLIOR CON %01000001
    GOTO START ' Bypass subroutines
    '--------------------------- SUB-ROUTINES ----------------------------
    RDISW1:
    I2CREAD SDAISW1,I2CSCL,I2CCTRL,I2CLOCB,[I2CWORD]
    PAUSE 12
    '-------------------------- MAIN PROGRAM -----------------------------
    START:
    PAUSE 2000
    LCDOUT $FE,1,"Program start"
    CYCLE:
    I2CCTRL = CTRLIOW
    I2CLOCB = LOCGPIO
    I2CWORD = LOWWORD
    GOSUB RDISW1
    I2CCTRL = CTRLIOR
    GOSUB RDISW1
    LCDOUT $FE,$94,BIN16 I2CWORD
    GOTO CYCLE
    Circuit coming up.
    Circuit:
    I tried reading from the INTCAP instead of the GPIO with much better results.
    Got more tests to do.
    EDIT: Nope, not that, nevermind...
    Feb 2004
    Germany
    Robert,
    As I'm not using the MCP23016 I haven't read the entire datasheet.
    But looking at your schematic there is one thing that may cause strange effects:
    you have switches to VDD, but no PullDown Resistors.
    So when the switches are open the MCP's inputs are floating.
    (I would prefer to have the switches connected to GND and have PullUps to VDD)
    I
    regards
    Ralph
    Thumbs up
    ARGH!
    Thanks Ralph! I can't believe I missed that. Pull-up resistors is one of those things that I watch out for in all switches.
    But I've been so busy learning new stuff on this circuit that I've totally forgotten what I consider to be a basic thing. I was so sure I had misunderstood something in the MCP23016 datasheet, or wired an I2C device improperly, a pull-up resistor never dawned on me.
    The circuit works beautifully now.
  1. I/O extender
    By mychangl in forum mel PIC BASIC Pro
    Last Post: - 20th November 2008, 15:56
  2. MCP23016 I2C serial I/O expander chip
    By GeoJoe in forum Serial
    Last Post: - 31st October 2007, 16:39
  3. MCP23016 I/O expander with PBP?
    By Jon Chandler in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2005, 10:32
  4. I2C I/O Expander PCF8574 hanging?
    By NavMicroSystems in forum Serial
    Last Post: - 4th August 2005, 03:26
  5. managing the I/O ports of the 16F84A
    By skyler_91600 in forum mel PIC BASIC
    Last Post: - 28th April 2005, 04:52
