MCP23016 I/O expander
Results 1 to 40 of 43
    Quote Originally Posted by mister_e
    Mr Demon,
    What is this Mister talk? I hope you're not doing the "vous" thing, 'cause if you are and you're just doing this to respect your elders, then I'm going to have to stroll over and hit you about the shoulders with my cane.
    :P
    Even if i don't see any advantage and/or need for the Optos, it also introduce, at least, a voltage drop between The PIC and the I2C device. No matter why it's working so so.
    I forgot about that.
    Schematic provided by Ralph will work. You just need to modify your I2CWRITE/I2CREAD statement to fit with the A0, A1, A2 jumpers.
    I don't have those arts on hand at the moment.
    On your SCL and SDA line, you should be able to fit all your I2C devices. As i remind MCPXXX don't have the same control word than your EEPROM so it shouldn't provide any conflict.
    Steve, I want to be able to have 8 MCP23016 for input, and another 8 for output, all on a single PIC. That's why I tried the MCT6 switch idea.
    Quote Originally Posted by NavMicroSystems
    For more than 8 (up to 16) devices of the same type share SCL for all of them and have separate SDA for each set of 8.
    Yeah, but the PIC 16F877 only has one SDA/SCL pair of pins. Is there another PIC that has multiple SDA lines (I didn't notice this feature on the MicroChip product list)?
    Feb 2004
    Germany
    Quote Originally Posted by Demon
    Robert,
    PBP's I2CWRITE / I2CREAD is "Software I2C" (not using the MSSP-Module), so you can use ANY I/O Pin.
    See PBP Manual Section 5.34 & 5.35
    regards
    Ralph
  1. I/O extender
    By mychangl in forum mel PIC BASIC Pro
    Last Post: - 20th November 2008, 15:56
  2. MCP23016 I2C serial I/O expander chip
    By GeoJoe in forum Serial
    Last Post: - 31st October 2007, 16:39
  3. MCP23016 I/O expander with PBP?
    By Jon Chandler in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2005, 10:32
  4. I2C I/O Expander PCF8574 hanging?
    By NavMicroSystems in forum Serial
    Last Post: - 4th August 2005, 03:26
  5. managing the I/O ports of the 16F84A
    By skyler_91600 in forum mel PIC BASIC
    Last Post: - 28th April 2005, 04:52
