MCP23016 I/O expander
Results 1 to 40 of 43
    "I don't see you initialising this chip. Last I checked it had twelve registers... let's set them up the way you'd like to see them.... then and only then you can perform I/O."
    The default values for all the registers seem to be what I want except for the IODIR register pair. According to the datasheet, we are able to write to both registers in a single write operation. The 1st I2CWRITE is supposed to write all ZEROES to both registers (IODIR0 and IODIR1):
    I2CCTRL = %01000000
    I2CLOC = $06 ' Set location to IODIR register pair
    I2CBYTE1 = %00000000 ' Set pins 0-7 as output
    I2CBYTE2 = %00000000 ' Set pins 8-15 as output
    I2CWRITE I2CSDA,I2CSCL,I2CCTRL,I2CLOC,[I2CBYTE1,I2CBYTE2],ERRORIO
    "Have you remembered to GROUND A2, A1 and A0 to match your IOCCTRL Byte?"
    Yup.
    "Have you remembered to leave TP floating?"
    Yup.
    "Have you remembered to GROUND all THREE Vss pins?"
    Yup.
    "Have you remembered Rext and Cext for your external Clock, or alternatively cross-connected it to Fosc of your PIC?"
    Yup, on the RC connection. I wanted to try your 2nd suggestion, but I can't see an Fosc pin on the 16F877.
    I've even connected all 16 I/O pins to LEDs, so I can easily see what is happening.
    Is there any particular reason why MicroChip would NOT include in the datasheet for the MCP23016 a little diagram of pull-up resistors on the data and clock lines?
    Who knows how long this has been working...
    Hmm, I have a feeling the pull-up resistor is more a requirement for the PIC 16F877 than for the MCP23016...
    4K7 pull-up's ARE required on the I2C lines.
    Feb 2004
    Germany
    regards
    Ralph
    Hmm, ok. I've gone through the datasheet more times than I can remember, but I never saw any mention of PU resistors on the clock/data lines. Is there any mention in it? Or are we 'expected' to know better?
    The only reason I thought of them is from reading the PBP Pro manual.
    If you put a scope on your I2C Bus, you would have realised the waveform didn't meet the specification of Table 2-5 in the Datasheet. Some devices do not require PU Resistors, PICs do... the clue could also have been found in the PBP manual I2C commands where an example schematic is given connecting to an external EEPROM. 4K7 is a good value when connecting one or two slave devices with a relatively short track between them. You need to drop this value for more devices or greater track capacitance. Refer to Raph's pointer to the I2C Bus Spec.
  1. I/O extender
    By mychangl in forum mel PIC BASIC Pro
    Last Post: - 20th November 2008, 15:56
  2. MCP23016 I2C serial I/O expander chip
    By GeoJoe in forum Serial
    Last Post: - 31st October 2007, 16:39
  3. MCP23016 I/O expander with PBP?
    By Jon Chandler in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2005, 10:32
  4. I2C I/O Expander PCF8574 hanging?
    By NavMicroSystems in forum Serial
    Last Post: - 4th August 2005, 03:26
  5. managing the I/O ports of the 16F84A
    By skyler_91600 in forum mel PIC BASIC
    Last Post: - 28th April 2005, 04:52
