More MCS+ Bootloader Questions
Results 1 to 8 of 8
    Feb 2005
    Saltburn by the Sea
    > 1. Will the bootloader work without the MCLR/DTR line?
    Yes, it will work fine.
    > 2. Ideally I'd also like to skip using the MAX232 chip...
    MicroCode Loader uses the MCUs hardware USART, which operates in true mode. You will therefore need a level inverter of some kind in order to connect to a PC.
    Sep 2005
    Dayton, Ohio
    David,
    Thanks for the info. I guess I'll just have to build a small programming "dongle" with the Max232 in it. Still better than adding an extra IC to every PC board.
    regards,
    Jim
    Feb 2004
    Germany
    Quote Originally Posted by milestag
    ...I guess I'll just have to build a small programming "dongle" with the Max232 in it...
    Jim, you can easily fit an SMD MAX233 inside a standard DB9 plug.
    All you then need is four wires to your target board.
    regards
    Ralph
    Feb 2003
    I have a couple of these on their way to me
    http://www.dontronics.com/micro-usb.html
    which I am hoping will enable me to bootload my projects with just a USB lead as my Laptop is legacy free and it seems pointless to go
    USB >> RS232 >> MAX232 >> PIC
    when I can go
    USB >> MicroUSB >> PIC
    I also have a couple of these colour LCD displays coming as well
    http://www.dontronics.com/micro-lcd.html
    I hope to be able to create some pretty cool Menu's for my project
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Feb 2004
    Germany
    Keith,
    ok, we're a bit off topic, but
    you should have a look at the LANTRONIX Xport
    regards
    Ralph
    David,
    You may consider this heresy but, ..... why not offer a version of Microcode Loader that operates from inverted logic? This may appeal to those not wanting a hardware interface, and maybe increase sales of MS+.
    Red face
    I may be wrong, but implementing inverted serial communication on the PC-side would NOT be an easy task. I have a feeling that it can't be done.
    If it can, I'd love to hear about it.
    It would be useful.
    Cheers.
    ---> picnaut
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 17:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 23:51
  3. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 22:29
  4. bootloader questions
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 20th August 2006, 20:01
  5. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 17:51
