calculate var Byte's and var Word's
Results 1 to 6 of 6
    Pedro Pinto's Avatar
    Pedro Pinto Guest
    Default calculate var Byte's and var Word's
    Hello All
    I need to calculate this example:
    varWord = (varByteA*365) + (varByteB*30) + (varByteC/2) + varByteD
    The PIC calculate always varWord = 0
    How can I write this, or must I before calculate copy the var's byte's in word's, like so
    varWordA = varByteA:varWordB = varByteB:varWordC = varByteC:varWordD = varByteD
    varWord = (varWordA*365) + (varWordB*30) + (varWordBC/2) + varWordD
    Thank for any help
    Best Regards
    Pedro
    BertMan's Avatar
    BertMan Guest
    If varByteC is not a multiple of 2, then the result is a floating point, which pbp doesnt support. Also, your word result can be no higher than 65535.
    Pedro Pinto Guest
    what I mean is:
    c var byte
    b var byte
    a var word
    c=12
    b=34
    a=c*b
    Is this correct, or must the var a and b be word var
    Pedro
    Pedro Pinto Guest
    sorry,
    Is this correct, or must the var b and c be word var?
    Pedro
    Only variables whose content is likely to exceed 8 bits need to be WORDS.
    In your example 'a' MUST be a WORD, 'b' and 'c' need not be.
    Pedro Pinto Guest
    Thank You Melany
    Pedro
  1. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 17:45
  2. LCD freeze
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 5th October 2009, 09:01
  3. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 07:34
  4. 16F877 RAM Question
    By Art in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 12:47
  5. Problems with variables
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 19:37
