PIC16F628A Time Switch
Results 1 to 3 of 3
    Dazzy's Avatar
    Dazzy Guest
    Default PIC16F628A Time Switch
    A am building a time switch with a PIC16F828A and I need a code that will enable it to keep time as well as scan a list of alarm times. is it possible and if so do you have a code?
    Thanks, Dazzy
    mmm perfect application to use an external RTC like DS1307.
    Melanie did an excellent code example http://www.melabs.com/resources/samp...ted/MN1307.txt
    this should be enough to start. The only things you'll have to add is the alarm... BUT as i know, there's some RTC with built-in alarm. Maybe somebody here can suggest you one.
    Feb 2004
    Germany
    Steve has already mentioned the DS1307
    As your request for a code example was your very first post, you should start HERE
    if you don't want to use an RTC, and had searched the Forum you would have ended up THERE
    There are many other RTC examples, do some searching...
    regards
    Ralph
  1. I don't understand this code!
    Last Post: - 13th February 2008, 03:55
  2. Replies: 14
    Last Post: - 26th September 2007, 06:41
  3. Can't get switch to work
    By JeffnDana in forum mel PIC BASIC Pro
    Last Post: - 4th April 2007, 21:44
  4. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 20:55
  5. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 15:24
