Setting OSC pins to o/p's
Results 1 to 6 of 6
    Feb 2004
    Michigan, USA
    Default Setting OSC pins to o/p's
    I need to use all the o/p's on my 16F818 and 2 are tied up with the resonator. I want to run using the internal 8MHz oscillator and use the 2 pins as o/p's. How do I program the fuse in EPIC to do that? I see an option for internal plus clock out on those pins.
    there's probably an option like Internal OSC I/O. And you will need to set MCLR to internal to free your RA5 pin.
    Personnally i prefer to do it in the code instead of setting config fuse manually in the programmer software.
    Look at the following to know how set the PIC config fuses in your code:
    Now, if my memory is good, the F818 default oscillator speed is 32KHZ, have a look to the datasheet in the Oscillator section. Search for the OSCCON register or something like that. Also look at the following link to Melabs Website
    http://www.melabs.com/support/mcu_hints.htm#81x
    Smile
    Hope this helps:
    'OSCCON VALUES FOR 16F818/819:
    'OSCCON = $00 '31.25 khz DEFAULT
    'OSCCON = $10 '125khz
    'OSCCON = $20 '250khz
    'OSCCON = $30 '500khz
    'OSCCON = $40 '1mhz
    'OSCCON = $50 '2mhz
    'OSCCON = $60 '4mhz
    'OSCCON = $70 '8mhz
    Feb 2004
    Michigan, USA
    Awesome guys, thanks for the replies. I'll let you know how I get on.
    Feb 2004
    Michigan, USA
    I got around to working on this today and couldnt get the config working correctly.
    I edited the 16f818.INC file and commented out the DEVICE CONFIG line. It solved the overwrite error.
    However, when I get into the EPIC programming screen, my configs are set back to EPICs defaults and it programs to whatever EPIC is set to. The config in the code is completely ignored. As I see it, there is no option in EPIC for having internal clock with I/O's, only internal clock with clock in, or clock out.
    So how do I get EPIC to program the device with the config in my code?
    Feb 2004
    Michigan, USA
    Nevermind, problem solved.
  1. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 15:01
  2. Problem setting pins on 12f675
    By srnet01 in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 16:58
  3. Change On Interrupt, PIC16F884
    Last Post: - 14th November 2008, 18:25
  4. Setting up the oscillator
    By J_norrie in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2007, 15:53
  5. Setting up 5 HPWM pins on 18F4680
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2006, 06:54
