Code doesn't work on 16F648A
Results 1 to 5 of 5
    Mar 2008
    Default Re: Code doesn't work on 16F648A
    I am having problems using an external oscillator on a 16f648a. I can use the internal oscillator with no problem however when I try to use an external ceramic oscillator the code does not run. On the config below if I change the second line to” cfg = _XT_OSC” I have no signs of function. I am sure it is something very simple I just cannot see the problem.
    cfg = _INTOSC_OSC_NOCLKOUT
    cfg&= _WDT_OFF
    cfg&= _PWRTE_OFF
    cfg&= _MCLRE_OFF
    cfg&= _BODEN_OFF
    cfg&= _LVP_OFF
    cfg&= DATA_CP_OFF
    cfg&= _CP_OFF
    __CONFIG cfg
    Mar 2008
    Sorry I got it because it was a 10mhz oscillator I needed to use "cfg = _HS_OSC" I found the answer in this pdf.
    http://ww1.microchip.com/downloads/e...tes/00849a.pdf
  1. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  2. Minimizing code space
    Last Post: - 30th May 2009, 08:25
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. Error code [112]/[113]
    By Dj tempo in forum General
    Last Post: - 17th June 2007, 17:15
  5. Replies: 1
    Last Post: - 31st August 2005, 21:00
