Current Meter
Results 1 to 17 of 17
Thread: Current Meter
    TK5EP's Avatar
    TK5EP Guest
    Default Yes, but ....
    Hi Alain,
    Maybe.... but the name problem is to insulate all the circuit from the high voltage side. The OPamp has to be supplied on this HV side, so you need low voltage supply which MUST be HV insulated.
    Maybe the Alegro can be adequate if its output is amplified to a level that can be handled by the PIC?
    Corsican greetings ...
    Quote Originally Posted by Acetronics
    Hi, TK5
    The best for that voltage levels ( !!! ) is to use a little shunt, an AOP and a V/F converter, then drive an opto-isolator or better an opto-fiber coupler ... remember only CNY21 like HV optocouplers are safe, here ...
    on the other side Freq = Current, so it's easy for a PIC to display that !!!
    Feb 2005
    Kolkata-India
    Default I use a piece of wire and an OP-AMP
    Hi there,
    Sorry to catch this thread late. I manufacture series of PIC controlled thyristor based battery charger. For low cost designs I use a piece of wire acting as a shunt in the negative line and then a LM358 for the amplification. It is safe to use it in a HV line also as long as it is referenced to ground. You can use a programmable gain IA like AD620 for your differential measurement needs and couple it to a linear optocoupler like the Vishay IL300. This gives far accurate results than the V/F approach and is cheaper. The only problem is you need another supply. Consider using the IRF PVI series of optos to make a 5ma supply isolated DC-DC converter as well as linear output opto. Maxim has got a very good appnote on high side current measurement (1KV).
    Whew! Enough gyans...
    If you could post a specific issue with detailed electrical parameter then I might find something on my Hard drive.
    BTW I always use a PIC with 10bits res. If thats enough then go on.
    Sougata
    TK5EP's Avatar
    TK5EP Guest
    Default Current measure
    Hi Sougata,
    Thanks for the ideas, my wish is to use no different supply on the HV side to supply the amplifier.
    I attached a GIF with the principle of the supply. You see that the supplies are not referenced to ground but to cathode of the tube.
    For the 350 V, i could make my measure on the grounded side of the supply, current can flow in both directions with max 50 mA.
    The 3500V HV will draw about 800-900 mA.
    The 36V only a few mA.
    Greetings,
    Quote Originally Posted by sougata
    Hi there,
    Sougata
  1. Reducing PIC current to as low as possible...
    By FromTheCockpit in forum mel PIC BASIC Pro
    Last Post: - 18th November 2009, 05:28
  2. Replies: 8
    Last Post: - 5th May 2009, 21:10
  3. Help from EE's on Power Meter (AN220)
    By SteveB in forum Off Topic
    Last Post: - 27th November 2006, 08:05
  4. 16F628A current high during sleep
    Last Post: - 9th October 2006, 11:21
  5. Detecting AC current
    By rhino in forum Off Topic
    Last Post: - 8th July 2005, 22:31
