Need info on B & K scope
Results 1 to 6 of 6
    georgex5's Avatar
    georgex5 Guest
    Red face
    Thanks for the info.
    The scope is 10x8x16"long. It has 2 channels, 2 inputs and 2 ground connections. As suggested, the ground connection unscrews and allows a lead to be connected. I presume this ground terminal is not the same as the ac power ground.
    I intend the use the scope only for some relatively simple audio hobby work. I have an Elenco scope but the input stage went bad and I don't have any way to fix it.
    The image posted by Steve is the correct one for the scope. A good way to present info. A very good forum.
    Regards, George
  1. Parallax USB scope
    By victorf57 in forum Adverts
    Last Post: - 15th July 2009, 04:18
  2. Need Info for PBP?
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 07:44
  3. Need info about RFID technology
    By microuser in forum Off Topic
    Last Post: - 10th September 2008, 09:43
  4. More info on L4620 liquid sensor chip
    By Nicmus in forum Documentation
    Last Post: - 1st June 2008, 23:03
  5. Need info on B & K scope
    By georgex5 in forum Off Topic
    Last Post: - 17th October 2005, 21:01
