I am just wondering how I can do couple of things on picbasic pro. Please follow the comments below.
TRISB = 1
TRISC = 0
i var byte ' generic i var to count
leds var byte[8] 'declaration of array
i = 0
while i < 8
leds[i] var portc.i
' I am just trying to set the array elements reference output pins
' like if I call leds[2] for example it should spit out portb.2
' is this possible in pic basic pro within a for loop?
i = i + 1
wend
while i < 8
'here I am trying to make them go high
'am I on the right track?
high leds[i]
i = i + 1
wend
' should I just use i var in here as well, or should I declare another variable?
while i < 8
low leds[i]
i = i + 1
wend
thanks for your suggestions.
iltertis
