I'm trying to make a differential thermostat for a solar water heating system, with a 16f876
and two DS1820 connected to 2 different pins of the pic. I started using as a base the onewire.bas
in the examples. Every thing was fine until, from a default fixed (7deg) temperature difference
between the 2 sensors I tried to have a variable one, say from 7 to 20 degrees, using a button.
It works but I get strange symbols displayed instead of the set temperature difference: hard
to memorize to say the least. Surely there must be a conversion problem that I do not
understand. Can anybody help me solving the problem? Any other suggestion will be very much
appreciated.
' Differential thermostat
temperature VAR WORD ' Temperature storage
count_remain VAR BYTE ' Count remaining
count_per_c VAR BYTE ' Count per degree C
temperapanel VAR WORD ' Panel temperature storage
count_rempan VAR BYTE
count_per_cpan VAR BYTE
DQ VAR PORTA.4 ' One-wire data pin for tank
DP VAR PORTA.5 ' One-wire data pin for panel*
delta VAR WORD ' Delta T° btwn Panel & Tank to start pump
DEFINE LCD_DREG PORTB
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTA
DEFINE LCD_RSBIT 2
DEFINE LCD_EREG PORTA
DEFINE LCD_EBIT 1
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
DEFINE LCD_COMMANDUS 2000
DEFINE LCD_DATAUS 50
ADCON1 = 7 ' Set PORTA and PORTE to digital
LCDOut $fe, 1, "Diff. Thermostat"
Pause 3000
delta = 700 ' DEFAULT T° DIFFERENCE AT WHICH PUMP STARTS
mainloop: IF PORTA.3 = 0 Then pressed ' CHECK IF TEMPERATURE DIFFERENCE
' BUTTON IS PRESSED
OWOut DQ, 1, [$CC, $44] ' Start temperature conversion
waitloop: OWIn DQ, 4, [count_remain] ' Check for still busy converting
IF count_remain = 0 Then waitloop
OWOut DQ, 1, [$CC, $BE] ' Read the temperature
OWIn DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE, Skip 4, count_remain, count_per_c]
' Calculate temperature in degrees C to 2 decimal places (not valid for negative temperature)
temperature = (((temperature >> 1) * 100) - 25) + (((count_per_c - count_remain) * 100) / count_per_c)
LCDOut $fe, 1, DEC (temperature / 100), ".", DEC1 temperature, "C Tank"
OWOut DP, 1, [$CC, $44] ' Start temperature conversion
waitloop2: OWIn DP, 4, [count_rempan] ' Check for still busy converting
IF count_rempan = 0 Then waitloop2
OWOut DP, 1, [$CC, $BE] ' Read the temperature
OWIn DP, 0, [temperapanel.LOWBYTE, temperapanel.HIGHBYTE, Skip 4, count_rempan, count_per_cpan]
temperapanel = (((temperapanel >> 1) * 100) - 25) + (((count_per_cpan - count_rempan) * 100) / count_per_cpan)
LCDOut $fe, $c0, DEC (temperapanel / 100), ".", DEC1 temperapanel, "C Panel"
Pause 3000 ' Display about once every 3 seconds
IF temperapanel < 1800 Then mainloop 'Less than 18°C? Pump stays off
IF temperapanel > (temperature + delta) Then 'Checks T diff. for the pump to start (default 7°C)
High PORTC.4 'Start pump
EndIF
IF PORTC.4 Then 'Check for PORTC pin 4 high
LCDOut $fe,$c0+4, " h2o PUMPING" 'It's high so pump is on
EndIF
IF temperapanel < (temperature +300) Then 'Checks if T difference < 3°C
Low PORTC.4 'Stop pump
EndIF
Pause 3000 ' Refresh time =~3 seconds
GoTo mainloop ' Do it forever
pressed: Pause 30 'debounce
IF PORTA.3 = 0 Then setdelta 'IF STILL PRESSED GO TO SETDELTA
setdelta: For delta = 700 TO 2000 STEP 100 ' STEP SIZE 1°C
LCDOut $fe, 1, "Delta ", delta 'CLEAR LCD AND DISPLAY DELTA VALUE
Pause 3000
IF PORTA.3 = 1 Then mainloop 'if not pressed go to mainloop
Next delta
GoTo setdelta
