Conversion problem
Results 1 to 5 of 5
    eva's Avatar
    eva Guest
    Default Conversion problem
    I'm trying to make a differential thermostat for a solar water heating system, with a 16f876
    and two DS1820 connected to 2 different pins of the pic. I started using as a base the onewire.bas
    in the examples. Every thing was fine until, from a default fixed (7deg) temperature difference
    between the 2 sensors I tried to have a variable one, say from 7 to 20 degrees, using a button.
    It works but I get strange symbols displayed instead of the set temperature difference: hard
    to memorize to say the least. Surely there must be a conversion problem that I do not
    understand. Can anybody help me solving the problem? Any other suggestion will be very much
    appreciated.
    ' Differential thermostat
    temperature VAR WORD ' Temperature storage
    count_remain VAR BYTE ' Count remaining
    count_per_c VAR BYTE ' Count per degree C
    temperapanel VAR WORD ' Panel temperature storage
    count_rempan VAR BYTE
    count_per_cpan VAR BYTE
    DQ VAR PORTA.4 ' One-wire data pin for tank
    DP VAR PORTA.5 ' One-wire data pin for panel*
    delta VAR WORD ' Delta T° btwn Panel & Tank to start pump
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EREG PORTA
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    ADCON1 = 7 ' Set PORTA and PORTE to digital
    LCDOut $fe, 1, "Diff. Thermostat"
    Pause 3000
    delta = 700 ' DEFAULT T° DIFFERENCE AT WHICH PUMP STARTS
    mainloop: IF PORTA.3 = 0 Then pressed ' CHECK IF TEMPERATURE DIFFERENCE
    ' BUTTON IS PRESSED
    OWOut DQ, 1, [$CC, $44] ' Start temperature conversion
    waitloop: OWIn DQ, 4, [count_remain] ' Check for still busy converting
    IF count_remain = 0 Then waitloop
    OWOut DQ, 1, [$CC, $BE] ' Read the temperature
    OWIn DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE, Skip 4, count_remain, count_per_c]
    ' Calculate temperature in degrees C to 2 decimal places (not valid for negative temperature)
    temperature = (((temperature >> 1) * 100) - 25) + (((count_per_c - count_remain) * 100) / count_per_c)
    LCDOut $fe, 1, DEC (temperature / 100), ".", DEC1 temperature, "C Tank"
    OWOut DP, 1, [$CC, $44] ' Start temperature conversion
    waitloop2: OWIn DP, 4, [count_rempan] ' Check for still busy converting
    IF count_rempan = 0 Then waitloop2
    OWOut DP, 1, [$CC, $BE] ' Read the temperature
    OWIn DP, 0, [temperapanel.LOWBYTE, temperapanel.HIGHBYTE, Skip 4, count_rempan, count_per_cpan]
    temperapanel = (((temperapanel >> 1) * 100) - 25) + (((count_per_cpan - count_rempan) * 100) / count_per_cpan)
    LCDOut $fe, $c0, DEC (temperapanel / 100), ".", DEC1 temperapanel, "C Panel"
    Pause 3000 ' Display about once every 3 seconds
    IF temperapanel < 1800 Then mainloop 'Less than 18°C? Pump stays off
    IF temperapanel > (temperature + delta) Then 'Checks T diff. for the pump to start (default 7°C)
    High PORTC.4 'Start pump
    EndIF
    IF PORTC.4 Then 'Check for PORTC pin 4 high
    LCDOut $fe,$c0+4, " h2o PUMPING" 'It's high so pump is on
    EndIF
    IF temperapanel < (temperature +300) Then 'Checks if T difference < 3°C
    Low PORTC.4 'Stop pump
    EndIF
    Pause 3000 ' Refresh time =~3 seconds
    GoTo mainloop ' Do it forever
    pressed: Pause 30 'debounce
    IF PORTA.3 = 0 Then setdelta 'IF STILL PRESSED GO TO SETDELTA
    setdelta: For delta = 700 TO 2000 STEP 100 ' STEP SIZE 1°C
    LCDOut $fe, 1, "Delta ", delta 'CLEAR LCD AND DISPLAY DELTA VALUE
    Pause 3000
    IF PORTA.3 = 1 Then mainloop 'if not pressed go to mainloop
    Next delta
    GoTo setdelta
    I can see a number of defects in your code. In the subroutine 'Pressed:'... herein you have some ambiguous statements... the first is...
    Since the next line is SETDELTA anyway, it seems a little pointless.
    The next problem is your use of the pressed subroutine. You adjust the variable DELTA from 700 to 2000 (7 to 20 Celsius) in steps of 100 with a delay of three seconds between them… 13 steps x 3 seconds means the user waits 39 seconds… a little long I would have thought.
    Then (this is your main problem) you are displaying the raw value of Delta with…
    Whereas you should have displayed…
    #delta
    The # symbol makes all the difference…
    And the routine always sets Delta to 700 and counts up, wouldn't it be better to adjust from the last value of Delta and roll back to 700 once 2000 has been exceeded?
    So, may I suggest the code is changed perhaps to something like...
    PortA.3 var PressButton ‘ Define adjustment Button
    Pressed:
    LCDOut $FE,1,"Delta : ",#Delta
    Pause 3000 ' Wait 3 seconds
    PressedLoop:
    If PressButton=1 then goto Mainloop
    Delta=Delta+100
    If Delta>2000 then Delta=700
    LCDOut $FE,$88,#Delta," "
    Pause 1000
    Goto PressedLoop
    Here we wait 3 seconds displaying the current value of Delta, thereafter if the button is still pressed we advance the value of Delta at a 1 second rate. Finally, NOT clearing the display, but simply overwriting the previous displayed value prevents the annoying flicker on the LCD.
    Melanie
    eva's Avatar
    eva Guest
    Smile
    Thank you very much Melanie,
    your solution and suggestion have been
    put succesfully at work!
    Eva
    Macedonia
    Default To Melanie
    I am new in this forum, and I have question abouth this:
    You replay massage to EVA with comment about errors on his software (differential thermostat for a solar water heating system using a 16f876 and two DS1820),
    I send post to EVA but no replay,
    can you help me with this,
    On Eva post is attached *.bas file. I need hex file but I do not have converter to do this,
    can you please do this for me.
    *.bas to hex for pic16f876)
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Again, try
    http://compilespot.com/
    for your hex code
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. 16F627A to 16F88 conversion problem
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 18th February 2009, 20:20
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 17:26
  3. A/D conversion problem on 18F4431
    By ttease in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 00:03
  4. Conversion Problem
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 18th March 2007, 13:09
  5. A/D conversion problem with pic16F88
    By Tapio Linkosalo in forum mel PIC BASIC Pro
    Last Post: - 18th August 2006, 12:42
