Simple Interrupt Program
Results 1 to 6 of 6
    eoasap's Avatar
    eoasap Guest
    ok, got it working! Thanks Steve. also added the pause and added a capacitor across the pushbutton to create an RC time constant and deal with the debounce.
    You guys are so helpful on here!
    you're welcome.
    Actually you don't need the capacitor, the debounce is done by software.
    Usually i choose 50mS as debounce delay.
    arthurok's Avatar
    arthurok Guest
    Default capacitor
    if you are scanning switches the capacitor dosent slow down your program "pauses and "button" command debouncing does.
    some engineer told me many years ago the computer does as its told you are its master and superior
    sure! but we talk about <50msec... even <20mSec. it's also depend what else your program is doing and how your program is done. Interrupt can happen really fast on some software.. slower on other. Always case by case.
    PushButtons aren't 0-1 signal... still present some odd result when releasing them.
    By software: We just check and insert a safe delay prior to return to the main program.
    By using capacitor: it just smooth the signal when releasing the switch... the old CMOS-TTL-...-.... to do it. I prefer the software method in many case. No additional parts and even if you have the most crapy switch in the world, you just need to modify 1 code line OR constant variable. Handy with some tact switches brand...
  1. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  2. USART interrupt in PIC16F877A
    By amindzo in forum General
    Last Post: - 26th August 2006, 18:51
  3. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 02:59
  4. Interrupt Problem
    Last Post: - 16th November 2005, 20:58
    Last Post: - 6th March 2005, 01:07
