Farnell's Rotary Encoder 733-726
Results 1 to 7 of 7
    Jul 2005
    Default Farnell's Rotary Encoder 733-726
    Hello
    I was looking for a rotary encoder and I found this 733-726, you can download its datasheets from here
    www.farnell.com/datasheets/48122.pdf
    I thought I can post the code I wrote for this encoder here before ordering...
    Please if any body got this kind of rotary encoders, then try this code and tell me if it works or not, also if any one has a suggestion to improve the code, don't hesitate to share....
    @ DEVICE PIC16F84A, HS_OSC, WDT_ON, PWRT_ON, PROTECT_OFF
    DATA $C0,$F9,$A4,$B0,$99,$92,$82,$F8,$80,$90
    Define Osc 4
    TRISA = %00011
    TRISB = 0
    PORTA = 0
    PORTB = 0
    INTCON = 0
    Index Var Byte : Index = 0
    A var PortA.0
    B vAR PortA.1
    ATemp var bit
    BTemp var bit
    atemp = a : btemp = b
    if atemp == btemp then
    while a == b : wend
    PAUSE 1
    if atemp <> a AND BteMP == B then VOL_UP ' CW Rotation Checking
    IF ATEMP == A AND BTEMP <> B THEN VOL_DOWN ' CCW Rotation Checking
    ' Indicate the incoming pulses and rotation direction
    ' with a 7-segment display.... Very Nice indeed....
    VOL_UP:
    read Index, PortB
    If index == 10 then
    index = 0
    Index = Index + 1
    GOTO MAIN
    VOL_DOWN:
    read index, PortB
    If Index == 0 then
    Index = 9
    index = index - 1
    Goto main
    A seven segmet display is used to allow visual indication of response, I tested this code with a wheel from an old mouse, it has three wires, black, red, and yellow, but results were annoying because of the bad wheel signals, but in essense the code is working fine...as I tried to pulse the inputs with a wire and three fingers...when I squeeze the wheel a little bit, it works very nice
    i don't know if will be handy but here's a snip of my encoder routine
    GetEncoder:
        OldPos = (PORTB & %11000000)>>6 ' get only PORTB<7:6> bits
        NewPos = OldPos
        ' see if encoder has move
        while ((NewPos==0) or (NewPos==3))
           NewPos = (PORTB & %11000000)>>6 ' get only PORTB<7:6> bits
        wend
        pause 20 ' debounce delay
        ' Get encoder movement
        '      Rotary encoder output table (clockWise rotation):
        '             00
        '             01 between move (half detent)
        '             11
        '             10 between move (half detent)
        '     Using XOR
        '               OldPOS   : 0     0     3     3
        '               NewPos   : 1     2     1     2
        '               movement : CW   CCW   CCW    CW
        '           XOR -------------------------------
        '                          1     2     2     1
        ' So, if NewPos XOR OldPos = 1 => increment
        '        Newpos XOR OldPos = 2 => Decrement
        Newpos=newpos ^ oldpos
        select case newpos
               case 1
                   Menupointer=menupointer+1
               case 2
                   Menupointer=menupointer-1
         end select
    Yeah i know, more comments than code but.. i like it
    Jul 2005
    Default encoder
    I have used these encoders and still have problems, I tried code supplied on this forum and it still does the same thing, it jumps up by 2 values instead of one ( rotate right one click generates 2 counts ). I do have the board set up still so I will try both code examples and advise.
    Nigel, Queensland, Australia
    Jul 2005
    Lightbulb
    Hello mister_e
    Thanks for the nice code.... and comments also
    I think I found my way of how to use these evil rotary encoders...
    Now, I don't know how to explain this very well, but I think the code will do..
    @ DEVICE PIC16F84A, XT_OSC, PWRT_ON, PROTECT_OFF, WDT_ON
    TRISA = 3
    TRISB = 0
    PORTA = 0
    PORTB = 0
    NEW VAR BYTE
    OLD VAR BYTE
    TEMP VAR BYTE
    DIRECTION VAR BIT
    INIT:
    TEMP = PORTA
    NEW = TEMP & 3 ' PortA<1,0> only required as inputs<B,A>
    START:
    OLD = NEW
    BEGIN:
    TEMP = PORTA ' Read the new value to see if changed
    NEW = TEMP & 3
    IF NEW == OLD THEN BEGIN ' If not changed, keep reading
    DIRECTION = NEW.1 ^ OLD.0 ' XOR left bit of new and right bit of old
    IF DIRECTION = 1 THEN CLOCKWISE
    COUNTERCLOCKWISE:
    GOTO START
    CLOCKWISE:
    GOTO START
    I tested this code with a mouse wheel, and it worked perfectly without any problems, I used 7 segment display to monitor the results. Tomorrow I will order the rotary encoder, and see if it also works as I intended...
    This method prevents double stepping each time the nob is rotated, try it guys, and tell me what is your experience like...
    Feb 2003
    Quote Originally Posted by wallaby
    Hi Nigel,
    I am about to use a rotary encoder for the first time and whilst trying to confirm the pinout with a multimeter I couldnt get any readings across any pins. I then went and found the datasheet and discovered I have bought a high resolution encoder.
    My encoder has 24 detents in common with many others, but many of the encoders have only 6 cycles per revolution so 4 clicks to go through 00,01,11,10
    Mine apparently has 24 cycles per revolution so a single click travels through 00,01,11,10 and back to 00. Basically whenever the encoder is resting on a detent BOTH switches are open. I confirmed this by using LED's and you can see the 4 steps during each click.
    Given that the code above will generate an output count whenever 00 or 11 are presented I guess that using the type of encoder I have will give a count of two for each click.
    Just need to code for that now
    Keith
    www.diyha.co.uk
    www.kat5.tv
    keithdoxey, I am the one that supplied Nigel with the code and it works perfectly with a standard encoder, however the encoder you have selected as well as Nigel are ment to be used in low power situations. That is why the encoder seems to be open circuited at rest or in the detented position. As I told Nigel, take the encoder count and divide it by 2 is the easiest way to use these type of "low power" encoders.
    Feb 2003
    Quote Originally Posted by Dave
    Hi Dave,
    Excellent idea. Just because I need a result of 0-63 doesnt meant I cant use an encoder value of 0-126 in steps of two.
    Will give it a try later.
    Keith
    www.diyha.co.uk
    www.kat5.tv
  1. Quadrature encoder and ASM Interrupts. questions..
    By godfodder in forum mel PIC BASIC Pro
    Last Post: - 17th March 2013, 14:45
  2. Calculate Distance Using Rotary Encoder
    By guanerrr in forum mel PIC BASIC Pro
    Last Post: - 4th May 2012, 16:40
  3. Rotary encoder help (not 'counting steps)
    By Elnino in forum mel PIC BASIC Pro
    Last Post: - 26th October 2009, 22:03
  4. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 21:56
  5. Automotive quality rotary encoder
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 8th October 2004, 15:46
