HSERIN HSEROUT 9BIT & PARITY (Output is Losing a bit!)
Results 1 to 13 of 13
    Default HSERIN HSEROUT 9BIT & PARITY (Output is Losing a bit!)
    I've got some 48000 bps 9,E,1 Data coming into a 12F1822 pic running at 32mhz.
    #config
     __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _FCMEN_OFF
     __config _CONFIG2, _PLLEN_OFF & _LVP_OFF
    DEFINE HSER_BAUD 48000	'Set Baud rate to 48000bps
    DEFINE HSER_BITS 9		'Set to 9 bit mode
    DEFINE HSER_EVEN 1		'Set Even Parity
    DEFINE HSER_CLROERR 1   'Clear overflow error automatically
    Start:						'Main program start
       hserin [wait($83), str IpuData\15]		'Rxd Data
       hserout [$83, str IpuData\15]			'Txd Data
    goto start
    My code basically waits for the start of a 16 byte packet and receives it then spits it back out again.
    I have been watching the data in/out with my Saleae Logic and the output seems to be one bit short!!
    I have two serial analyzers running with the same settings. 48000 bps, 9,E,1
    The top line/channel is the incoming data which decodes correctly.
    The second line is the outgoing data but is does not decode correctly and each byte seems to be one bit short!
    If I change the settings of the Saleae output analyser to 8 bit with parity then the data is correct.
    So the pic is receiving it correctly but the hserout is wrong for some reason.
    Where is my missing bit?
    The device that receives this data ultimately is refusing it because it is not the correct length..
    Why this discrepancy? What am I missing?
    Serin2 also exhibits the same behavior?
    I had to resort to Microsoft edge to post this as Chrome still gives too many redirects errors.
    Aug 2011
    Default Re: HSERIN HSEROUT 9BIT & PARITY (Output is Losing a bit!)
    The hardware uart can't do 9E1... that would require 10 bits.
    Maybe I mislead you then, sorry I mean 8,E,1 (1 start bit, 8 data bits, 1 parity bit and one stop bit)
    The below sort of works just moving the 9th bit and the 8 Bit data straight across from the RX to TX.
    The receiving device is now accepting the input but Saleae logic still shows errors in the data the PIC is outputting???
    Something weird is going on..
       do while PIR1.5 = 0                        'Wait for RX  data
       loop
       do while PIR1.4 = 0                        'Wait for TX to be ready
       loop
       TXSTA.0 = RCSTA.0
       TXREG = RCREG
    goto start
    If you still have the protocol decoder set to 9E1 then I believe that would be the problem since the output from the PIC is 8E1 (11bits total). Likely the input is 8E1 as well, don't you think?
    Yes but setting the decoder to 8E1 on the input gives parity errors. ???
    Attached is some logic 1.2.40 data. The top line is the incoming data.
    Perhaps some kind soul could have a look at it and see what they make of it.
    Have I got the baud rate/parity etc right for the incoming data decoder?
    I've tried loads of variations!!
    The shortest pulse is about 20us
    Note the output data is now at least the same length as the input and the receiving device seems to accept it, but the output decoder with the same settings as the input gives errors!!!
    LogicData.zip
    Aug 2011
    If you set both channels of the protocol decoders to 8 data bits, odd parity, 1 stop then the errors go away (8O1), but I don't know about the data.
    Are you sure about the format? You don't include the parity bit in the count of data bits. Typical formats would be 8N1, 8E1, or 8O1.
    Normally, in 9-bit mode there's no parity used (9N1).
    Yeah, like tumbleweed says, it does seem to be ODD parity, not EVEN.
    I think you are both right. Thanks a lot.
    I had tried lots of combos!!! But missed odd parity...
    Attached is another Saelea logic data file in which I am struggling to work out the baud rate and parity etc.
    It's from a similar device to my earlier posts in this thread so logically you would think format etc would be similar.
    The shortest pulse/bit is about 19.30us so that equates to about 51813bps
    But that doesn't work in the analyser unless I am missing something.
    Only 55000 8, E,1 seems to decode without errors??
    But I'm not convinced that is correct.
    If I then program my PIC with that baud rate etc it returns garbage or misses the data entirely.
    I've even tried using osctune to shift the PIC baud rate up and down but no joy yet.
    I'm tempted to try autobaud but that looks pretty tricky from the PIC16F886 datasheet.
    What do members think the data rate/parity is of the attached file?
    Aug 2011
    48000, 8o1 seems to work
    That gives loads of errors for me..
    This seems to work??
    Aug 2011
    Oops, I grabbed the wrong file. Sorry!
    What you have there seems to work... 48000 E81 (but the timing is REALLY tight for 48000)
    Just an fyi - when you try these don't pick '9-bit + parity' modes, at least not to start. It's usually either '8 data + parity' (if there is a parity) or '9 data w/no parity'.
    Most UARTS won't do 9 data bits + a parity bit
  1. Replies: 8
    Last Post: - 11th July 2011, 20:20
  2. Loading a BIT array, losing my mind!
    By PlantBob in forum mel PIC BASIC Pro
    Last Post: - 19th January 2011, 13:26
  3. Hserin & Hserout - Trying to blink an LED
    Last Post: - 24th May 2010, 12:25
  4. Bit/Byte array for Hserin/Hserout
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 1st September 2006, 23:07
  5. 8 data and parity using HSERIN, HSEROUT
    By Smity42 in forum Serial
    Last Post: - 3rd April 2006, 01:45
