Hello, this is my first time in this forum, sorry for my bad english.
I built the circuit with the pic16f877, i2c memorys, max 232,etc...all run ok, but I have a problem with the i2c rtc pcf8583 Philips, this real time clock no run, I tested the circuit and good all device, but when I put my hand in the circuit this rtc begin run ok, I tested again the circuit, I don,t see cold solder, bad contact,etc..only when i put my hand in the crystal 32768 Khz is run, but when I put off the hand donīt run. I change the crystal, change the chip, I solder the box crystal to ground, but impossible, donīt run. Please I need help me , I donīt Know wht happen in my circuit. Thank you very much
Carlos from Canarys Islands
