pcf8583 rtc
Results 1 to 4 of 4
Thread: pcf8583 rtc
    AGUERE's Avatar
    AGUERE Guest
    Default pcf8583 rtc
    Hello, this is my first time in this forum, sorry for my bad english.
    I built the circuit with the pic16f877, i2c memorys, max 232,etc...all run ok, but I have a problem with the i2c rtc pcf8583 Philips, this real time clock no run, I tested the circuit and good all device, but when I put my hand in the circuit this rtc begin run ok, I tested again the circuit, I don,t see cold solder, bad contact,etc..only when i put my hand in the crystal 32768 Khz is run, but when I put off the hand donīt run. I change the crystal, change the chip, I solder the box crystal to ground, but impossible, donīt run. Please I need help me , I donīt Know wht happen in my circuit. Thank you very much
    Carlos from Canarys Islands
    Did you include a capacitor from +5V to the OSCI input? What size is it?
    I think it should be around 10pF
    AGUERE's Avatar
    AGUERE Guest
    Thank you , for your reply. I built the circuit with the chip philips pcf8583, the pin 1 osc1, and the pin 2 osc0, I put the crystal 3.2760 and the pin 1 I put the capacitor 5-25 pf + 5 v, but I change the capacitor 22 pf, but nothing, I think is necesary programming the commands for running this chip. I programming only read date and time from pic, no write to new time, date. Please if you have diagram, or ex. this pcf8583 please send me. Thank you very much
    Here are a couple of exaples using the PCF8583 from other
    http://www.decadenet.com/pub/kashin.txt which is part of a video overlay project at http://www.decadenet.com/bob2/bob2.html
    This one is actually for Proton+ so may be a liitle confusing, but it is similar enough to hlp.
    http://users.picbasic.org/projects/D...ata_logger.htm
  1. Low battery signal from an RTC
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 19th March 2008, 18:13
  2. PIC 16F877 I2C communications
    By sigmoideng in forum General
    Last Post: - 13th July 2007, 11:28
  3. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
  4. X1226 RTC - Help
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 18:54
  5. PCF8583 RTC alarm?
    By wjsmarine in forum mel PIC BASIC Pro
    Last Post: - 18th October 2005, 01:12
