LCDOUT -> Count Value
Results 1 to 5 of 5
    eoasap's Avatar
    eoasap Guest
    Default LCDOUT -> Count Value
    I'm having a hard time trying to do this. this is my configuration and code so far if anyone can help:
    hardware: PIC16F84
    PORTB.2 has a pullup resistor to VCC
    pushbutton switch connected to PORTB.2 to gnd.
    I inserted 'high pushbutton' because once i press the button, the output port did not automatically go back to VCC afterwards (right?, wrong?)
    CounterA var Byte 'for counter
    PushButton var PORTB.2
    If PushButton=0 then
    CounterA=CounterA+1
    pause 10
    high pushbutton
    Pause 10
    While Pushbutton=0:Wend
    Lcdout $fe, 1, "Button Presses =" ' Clear LCD screen
    Lcdout $FE, $c0, Countera
    Pause 2000
    tegel2's Avatar
    tegel2 Guest
    By making the pin High, you have made the port an output !!!
    You are then shorting the output to ground and may have damaged your Pic.
    eoasap's Avatar
    eoasap Guest
    ahh!!! so remove the pullup resistor then and hope the chip isn't fried? does the rest of the code look ok?
    tegel2's Avatar
    tegel2 Guest
    Keep the resistor - a good value is 10k
    CounterA=0 ' will be an undefined value on startup
    Start:
    CounterA=CounterA+1
    Pause 2000
    goto start ' must tell the program where to go otherwise it will crash
    eoasap's Avatar
    eoasap Guest
    hmm, still not working. i think i need to try to setup an interrupt. this way regardless of what the program is doing it'll record the button press. i'll poke around the forums and see what i can learn
    Thanks alot for your help!
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 07:56
  2. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 07:31
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 02:33
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 15:04
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 12:22
