DATA on a PIC18F252
Results 1 to 5 of 5
    http://www.picbasic.co.uk/forum/showthread.php?t=547
    There are no current issues with DATA and internal EEPROM.
    I can't vouch for MCS because I don't use it.
    Hangover, Germany
    Hello Melanie,
    thank you for your answer. I've found the long thread from you too.
    I think the conclusion is - buy a programmer from Melabs !
    And this is not realy my solution - I will look inside the Assembler vom Microchip.
    I don't use any MeLabs programmers. If your programmer and its software is good it should work. It's all down as to how the HEX file is created... that's down to PBP and MPASM... if you're up-to-date you should have no issues.
    As an aside, the 16F872 I've been using since at least PBP 2.42 with the MeLabs PM Assembler by default (that's a good three/four years now)... never any problems with internal EEPROM.
    Hangover, Germany
    Hello Melanie,
    I think the problem is the program IC-Prog !
    The 16Fxxx and the 18Fxxx uses another syntax to store the EEPROM-data into the hexfile.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 03:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
