Bug ? Error in calculating constants
Results 1 to 2 of 2
    Hangover, Germany
    Default Bug ? Error in calculating constants
    Yesterday i've broken down an interesting bug:
    Takt CON 40
    Prescaler CON 2
    UPM VAR WORD
    T8 VAR WORD
    UPM=((Takt/Prescaler)*25000/8)/T8
    is working wrong, because "(Takt/Prescaler)*25000" is bigger than 16 Bit - but there is no overflow-error !
    using
    UPM=((Takt/Prescaler)*(25000/8))/T8
    works !
    PBP 2.44
    Dec 2003
    Wichita KS
    Hello Big Wompus,
    BW>>UPM=((Takt/Prescaler)*25000/8)/T8
    using
    works !
    The reason why your second series works, is because you are doing the Calculations *inside* the parenthises <sp> first.
    You must take in order the compiler does your calculations....
    parentheses are ALWAYS done first
    Value = 3 + 4 * 5; Value = 35
    Value = 3 + (4 * 5); Value = 27
    Value = (3 + 4) * 5; Value = 35
    Now working with integers...
    Value = 3 + 4 / 5 + 6 Value= 7 if compiler reads left to right
    Value = 3 + 4 / 5 + 6 Value= 10 if compiler does Multilplication ahead of addition
    Value = (3 + 4) / (5+6) Value = 0
    You must be careful on using parentheses and how a compiler computes values. I *always* use parantheses, so that I will force the compiler to calculate my values correctly... nomatter which order a compiler runs through complex calulations.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
  1. 18F25K20 and EEPROM - Bug ???
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2009, 22:14
  2. Did I find a bug or bug found me?
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 13th September 2008, 10:58
  3. calculating arc tangent
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 14th July 2005, 08:29
