I am looking into trying to build a converter that will take 38400 baud async serial data and convert it to 38400 baud sync serial data. This is a directional converter (it only receives async and transmits sync). My thoughts were to use a MAX3235 RS-232/TTL converter and tie the receive and transmit TTL lines together to pass the data thru. I would tap into the TTL line with a PIC (thinking about a 16F628) and generate a clock signal that would be fed to the second TTL-232 converter in the MAX3235. This would (hopefully) generate a clock pulse every time a serial bit is received.
I looked into using HSERIN, but it seems that this command, along with all the other serial commands, will end up dealing with bytes and I need to deal with bits (one bit, one clock pulse). Does anyone have any ideas here? I have very little (none, actually) experience with assembly.
