Help please!
Results 1 to 3 of 3
Thread: Help please!
    Smile Help please!
    I understand, what I want is to be able to modify the value to count by means of a keyboard 4x4 and a lcd for not having to reprogram every time that the wants to modify the I number from maximum pulses to count.
    For example: to show in a lcd
    Push buttom RB0 to increase the value to count
    Push buttom RB1 to diminish the value to count
    Push buttom RB3 enter to record the value
    Somebody can help me.
    code
    TRISB=%00001111 ' Set RB0 to input, others to output
    OPTION_REG.7=0 ' Enable internal pull-up on PORTB
    LED VAR PORTB.7 ' connected between RB7 and GND via resistor
    LED1 VAR PORTB.6
    BOT VAR PORTB.1
    ClkIn var PORTB.0 ' connected between RB0 and GND
    Apulse VAR BYTE ' store the amount of pulse
    Apulse1 var byte
    data @0,0,0
    read 0,apulse
    read 1,apulse1
    led = 0
    led1= 0
    paso1:
    repeat
    if clkin=0 then
    while clkin=0 : wend
    apulse=apulse+1
    write 0,apulse
    if BOT=0 then
    while BOT=0 : wend
    apulse1=apulse1+1
    write 1,apulse1
    until (apulse=7) or (Apulse1=5)
    if apulse=7 then
    led=1
    led1=1
    goto paso1
    Smile
    code
    LED1 VAR PORTB.6
    BOT VAR PORTB.1
    Apulse1 var byte
    data @0,0,0
    read 0,apulse
    read 1,apulse1
    led = 0
    led1= 0
    paso1:
    repeat
    if clkin=0 then
    apulse=apulse+1
    write 0,apulse
    if BOT=0 then
    while BOT=0 : wend
    apulse1=apulse1+1
    write 1,apulse1
    if apulse=7 then
    led=1
    led1=1
    goto paso1
    Smile Help LCD
    code
    LED1 VAR PORTB.6
    BOT VAR PORTB.1
    Apulse1 var byte
    data @0,0,0
    read 0,apulse
    read 1,apulse1
    led = 0
    led1= 0
    paso1:
    repeat
    if clkin=0 then
    apulse=apulse+1
    write 0,apulse
    if BOT=0 then
    while BOT=0 : wend
    apulse1=apulse1+1
    write 1,apulse1
    if apulse=7 then
    led=1
    led1=1
    goto paso1
