display lcd variable array Ascii
Results 1 to 9 of 9
    Quote Originally Posted by DynamoBen
    I don't know that there is a short hand way to do that. In the past I have either made the string ASCII via addition or written one byte at a time to the lcd.
    BTW I tend to use DEC variable in place of # variable.
    not there are other solutions?
    Jun 2005
    Wisconsin
    Do this....it works great.
    For idx = 0 to 7
    LCDOUT $FE, 1, #var[idx]
    next idx
    Aug 2005
    lcdtest var byte[3]
    lcdtest(0)="1" 'ASCII value for 1
    lcdtest(1)=$32 'HEX value for 2
    lcdtest(2)=51 'DEC value for 3
    'Cear Display and Output to line 1
    LCDOUT $FE,1,str lcdtest\3
    Will display 123 on LCD.
    Sean.
    Thanks to all however I have resolved using the commando lookup
    Quote Originally Posted by sean-h
    lcdtest var byte[3]
    Sean.
    hello!
    which it is the difference between:
    I2CREAD SDA,SCL,pag1,0,[str password\4]
    LCDOUT $FE,1,str password\4
    it is
    for ind_ep = 0 to 3
    I2CREAD SDA,SCL,pag1,ind_ep,[password[ind_ep]]
    pause 20
    next ind_ep
    Jun 2005
    Wisconsin
    You don't need to pause when reading an I2C buss. You only really need a pause when writing to it.
    Both examples are functionally the same. The first one is much easier to ready.
    Nitro's Avatar
    Nitro Guest
    Default another way?
    couldnt you just say
    lcdout "var="
  1. Hdsp 21xx display
    By Original in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 21:07
  2. LCD Display
    By lambert in forum mel PIC BASIC Pro
    Last Post: - 16th January 2010, 23:18
  3. assembly in Pic
    By lerameur in forum Off Topic
    Last Post: - 1st May 2008, 21:06
  4. LCD display not working properly
    By dilpkan in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 08:43
  5. LCD Display not working - PIC heating...
    Last Post: - 24th September 2006, 08:35
