display lcd variable array Ascii
Results 1 to 9 of 9
    Unhappy display lcd variable array Ascii
    Hello!
    If I want to writer the value of a variable one in ASCII on a display I write LCDOUT $$FE, 1, #var1 that is I precede with the # var1, if the same thing with an Array is wanted to be made as it could be made? sintax is LCDOUT $$FE, 1, str var\08 if I put # before var the compiler gives me error.
    Jun 2005
    Wisconsin
    I don't know that there is a short hand way to do that. In the past I have either made the string ASCII via addition or written one byte at a time to the lcd.
    BTW I tend to use DEC variable in place of # variable.
    Quote Originally Posted by DynamoBen
    not there are other solutions?
    Jun 2005
    Wisconsin
    Do this....it works great.
    For idx = 0 to 7
    LCDOUT $FE, 1, #var[idx]
    next idx
    Aug 2005
    lcdtest var byte[3]
    lcdtest(0)="1" 'ASCII value for 1
    lcdtest(1)=$32 'HEX value for 2
    lcdtest(2)=51 'DEC value for 3
    'Cear Display and Output to line 1
    LCDOUT $FE,1,str lcdtest\3
    Will display 123 on LCD.
    Sean.
    Thanks to all however I have resolved using the commando lookup
    Quote Originally Posted by sean-h
    lcdtest var byte[3]
    Sean.
    hello!
    which it is the difference between:
    I2CREAD SDA,SCL,pag1,0,[str password\4]
    LCDOUT $FE,1,str password\4
    it is
    for ind_ep = 0 to 3
    I2CREAD SDA,SCL,pag1,ind_ep,[password[ind_ep]]
    pause 20
    next ind_ep
  1. Hdsp 21xx display
    By Original in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 20:07
  2. LCD Display
    By lambert in forum mel PIC BASIC Pro
    Last Post: - 16th January 2010, 22:18
  3. assembly in Pic
    By lerameur in forum Off Topic
    Last Post: - 1st May 2008, 20:06
  4. LCD display not working properly
    By dilpkan in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 07:43
  5. LCD Display not working - PIC heating...
    Last Post: - 24th September 2006, 07:35
