Matrix keyboard and sleep
Results 1 to 5 of 5
    Default Matrix keyboard and sleep
    I am trying to get rid of double keypress of the same key in the matrix keyboard that is scanned by the PIC 16F886 after it wakes up from sleep.
    Not always but random times some of the key presses are detected two times. I think either a debounce or waiting for key release could help but cannot find a way to make it work.
    After any key press a beep is generated to give feedback.
    The 886 is in sleep and IOC is enabled to detect keypress of the matrix.
    Then flag pressed is set and main routine takes over.
    Attached is the program. Just delete the .txt extension.
    RCT-100.pbp.txt
    OK
    Default Re: Matrix keyboard and sleep
    I didn't download your program, as I surf with my Mac and PBP on my PC. I would have to thumb-drive it over to look. However, the debounce procedure that works well for me it to detect a button press, then pause about 50 ms to see if it's still pressed. Then wait until it is no longer pressed, and wait another 50 ms. Something like this:
    IOC_ISR:
    IF PORTB.4 = 1 THEN  'Button is pressed
      PAUSE 50  'Give it a chance to stabilize
      IF PORTB.4 = 1 THEN  'Recheck to verify button press
        WHILE PORTB.4 = 1  'Wait until button is released
        END WHILE
        PAUSE 50  'To give any rogue static bounces a chance to fizzle
        'Take Action Based on Button Press
    I've been coding in XC8 for the past couple years. My PBP is getting a bit rusty. Forgive me if my syntax isn't correct, but hopefully you get the gist of what I'm trying to accomplish.
    Thanks Mike.
    The problem is that the keyboard is a matrix one that is scanned to see which key was pressed. This complicates the case...
    OK
    Maybe you could use a Timer to mask recently pressed buttons. When PORTB.4 IOC triggers, disable the IOC Interrupt for that pin, start your 50 ms Timer, then in the Timer ISR restore all IOC Interrupts, regardless of which one you disabled for the mask.
    I am not sure why you mention the portb.4 bit but regardless, the idea to use timer is good. Thanks.
    Matrix keyboard is more complicated in that aspect, also if sleep is also involved.
  1. 10x4 matrix keyboard using only portB
    By aratti in forum Code Examples
    Last Post: - 16th November 2011, 09:39
  2. Matrix keyboard for up to 32 keys
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 21st June 2009, 01:43
  3. Keyboard Matrix with a Twist
    By k3v1nP in forum mel PIC BASIC Pro
    Last Post: - 29th October 2008, 10:51
  4. LCD + keyboard matrix minimal I/O
    Last Post: - 21st June 2006, 19:49
  5. Matrix keyboard problem
    By MegaADY in forum mel PIC BASIC Pro
    Last Post: - 9th May 2005, 18:50
