I believe he is trying to determine if functionally PICBasic and C are comparable. I'm not an expert by no means but from what I have seen both seem to be pretty equal.
Personally, I use Basic because that is what I learned in H.S. As a hobbyist I can do anything the C guys can do with PicBasic. In many cases, I can whip something together and have it functioning more quickly.
You can either spend time learning C or you can be developing using PicBasic.
I like PicBasic, and jump between it and assembly for most of my commercial and personal projects. I have not learned C, but I wonder if something about C makes it superior for certain operations.I know alot of app source software I work with is written in it, and I would like to know it a little better to understand the program flow.
Hello
I learnt CCS C compiler, because I did not want to ask any one which is better, thats a stupid question to ask (Sorry), I may think of a girl as the most beautiful one on earth, while you say, nah, she is not...its all up to you, and your needs, programming taste, etc...
Don't expect me to tell you which one is better, or what pros and cons of each compiler...
What I wanted to say is this:
Read PICBasic Pro manual again, and CCS C compiler manual too...for both manuals, read what each compiler has, for example, try to figure out the supported data types in each compiler, Byte, Word, Int, Float, double....Also read the built in functions to know if a compiler really meets your technical requirements, as steve used to say, don't trust anybody except your self, so read the manual and you will be able to decide with which one to go...don't expect any one to come and say, oh, CCS C compiler has string manipulation functions that are not found in PICBasic Pro, ok.
I have used the CCS C compiler for two months only and just for testing and comparing purposes, then I quit, although I like it, but for unknown reason I hate C and C++, and like VB.NET, also I still prefer and trust PICBasic Pro, its simple and gets the job done, and the most important, fulfills my technical requirements
Good luck
