Can RESUME replace RETURN in a GOSUB?
Results 1 to 7 of 7
    Default Can RESUME replace RETURN in a GOSUB?
    Hello Everyone. I broke the rules and have a GOSUB that could possibly never get cancelled under certain conditions. I haven't had a problem yet but I have read posts by others on this forum who have had problems when a GOSUB never gets cancelled. Can I replace BADCODE with GOODCODE to get the same results? Thank you. - Peter
    BADCODE:
    SOMEWHERE IN MY CODE:
    IF PORTA.1 = 1 THEN GOSUB DOSOMETHING
    DOSOMETHING:
    IF PORTB.2 = 1 Then Return 'NO PROBLEM - GOSUB GETS CANCELLED
    IF PORTA.5 = 0 Then Return 'NO PROBLEM - GOSUB GETS CANCELLED
    IF PORTB.0 = 0 Then START '***HERE IS THE PROBLEM - GOSUB MAY NEVER GET CANCELLED
    GoTo DOSOMETHING 'STAY HERE UNTIL RB2, RA5 OR RB0 DOES SOMETHING
    GOODCODE:
    IF PORTA.1 = 1 THEN DOSOMETHING 'REMOVE THE GOSUB
    DOSOMETHING:
    IF PORTB.2 = 1 Then RESUME 'IS THIS THE SAME AS A GOSUB RETURN?
    IF PORTA.5 = 0 Then RESUME 'IS THIS THE SAME AS A GOSUB RETURN?
    IF PORTB.0 = 0 Then START 'IS THIS A GOOD REPLACEMENT FOR BADCODE?
    Dec 2003
    Wichita KS
    Hello Peter,
    Peter>>I broke the rules and have a GOSUB that could possibly never get cancelled under certain conditions. I haven't had a problem yet but I have read posts by others on this forum who have had problems <<
    I think you are asking the wrong question to yourself... I think you should be asking yourself:
    "Why Chance it?"
    Good Ol Murphy will get you sometime or another. If you know there is a known problem, and you have found that known problem, and it is a fixable situation....I would fix it...ASAP. It is not worth the headache when it dies.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Thanks Dwayne. That is what I am trying to do. If I can substitute RESUME with GOSUB and RETURN this should fix it right? The alternative is to break down about 200 lines of code and find an alternative. The subroutine START that I have in my bad GOSUB code is very important. It addresses, powers down other chips, checks for button & switches & has to be there. - Peter
    Hi Peter,
    The RESUME command does the same thing as a RETURN, except that it also turns on the GIE (INTCON.7) bit to re-enable Interrupts. &nbsp; Not a good idea if your program isn't set-up to handle interrupts. And, since it's still a RETURN, it doesn't solve your problem.
    However, unlike Visual Basic, the program doesn't have to return from the exact same Subroutine that was called to begin with. You can GOTO another section of code and then RETURN from there.
    BADCODE:
    DOSOMETHING:
        IF PORTB.0 = 0 Then DoSomethingElse
    DoSomethingElse:
    Or, if you want it to jump somewhere that doesn't return, you can set a "Flag" in the subroutine, and act on it in the main loop.
    FlagBit  VAR  BIT
    BADCODE:
        FlagBit = 0
        IF FlagBit = 1 then START
    DOSOMETHING:
        IF PORTB.0 = 0 Then FlagBit = 1 : Return
    This way, the RETURN has been satisfied, so you're free to GOTO anywhere.
    Thank you Darrel. I thought
    was the same as
    If it is the same, isn't it going to RETURN regardless of PORTB.0 or Flagbit? Does the first statement RETURN only when PORTB.0 = 0? Thank you. -Peter
    DOSOMETHING:
    You can have several statements on a single line and they will all be executed ONLY if the IF is true.
    IF A = B then C = A : LOW PORTB.0 : PAUSE 100 : RETURN
    Which is the same as ...
    IF A = B then
    &nbsp;&nbsp;&nbsp;&nbsp;C = A
    &nbsp;&nbsp;&nbsp;&nbsp;LOW PORTB.0
    &nbsp;&nbsp;&nbsp;&nbsp;PAUSE 100
    &nbsp;&nbsp;&nbsp;&nbsp;RETURN
    HTH
    Hi Darrel. You have opened up a whole new way for me to accomplish certain tasks. I migrated from a different basic compiler which doesn't support multiple commands on a single line. Being able to do this solves a lot of problems. - Peter
  1. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 12:45
  2. shifting problem
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 07:11
  3. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  4. ds1307 from f877 to f452 not work
    By microkam in forum mel PIC BASIC Pro
    Last Post: - 7th July 2005, 01:02
  5. Mssp
    By capitano in forum Code Examples
    Last Post: - 15th December 2004, 20:33
