Window Comparator and Direction
Results 1 to 5 of 5
    Dec 2021
    Illinois, USA
    Default Window Comparator and Direction
    I know this has been asked and I looked at many of the replies but at 75 years young I am having a bit of trouble wrapping my head around the best way to do this. I have an adc value that I am trying to maintain in a window. I am comparing an adc reading to a reference and trying to decide if it is in a +/- 40 count range. If not, I need to determine the direction to run, i.e. Vadc - Vref is positive or negative result. What I am having trouble with is the possibility of the answer being negative (PBP returning 65536-value) and therefore looking greater than the reference because of the way negative numbers are handled and getting a wrong direction. I suppose I could use Long variables since I am using a PIC18F but I am just looking to understand the logic.
    Thanks for helping with my post-retirement education.
    Default Re: Window Comparator and Direction
    maybe like this , the msb of a var is the sign bit
    to convert between unsigned an signed use abs() or vice versa var=~var+1
    Vadc var word
    Vref var word
    vDif var word
    aDif var word
    vDif = Vref -  Vadc ;signed difference
    adif= abs(Vref -  Vadc);absoloute unsigned difference
    if vDif.15 then
    do  negative stuff
    do positive stuff
    Dec 2021
    Illinois, USA
    Thanks Richard,
    it's the format of the ABS that has been confusing me. According to what I read in the manual, the ABS function for a word variable returns 65536 - value. So if I had a negative number and did the ABS() of that, it could return a number that is larger than the number I was taking the ABS value of. If my number was -40 for example. That would be 1111111111011000 in binary. (-40) If I do the ABS value function I think it returns 0000000000101000 which is 40! Wow, I was subtracting from 65535 not 65536. The light just went on! Thanks again Richard, sorry to ask such a dumb question!
    If your ADC is the ADC inside the PIC then it is a possitive value.
    If you use external ADC then I guess it can be negative also.
    Dec 2021
    Illinois, USA
    Red face Re: Window Comparator and Direction
    I am using the internal ADC on the PIC18F45K80 but the question I was having was determining if I was inside a window of +/- 40 counts. I was concerned that RefPosition - CurPosition could give me a negative result but I see how to handle it now. Thanks for all the help.
  1. Replies: 2
    Last Post: - 31st May 2013, 18:19
  2. Check within a 16 bytes window
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 29th November 2012, 11:54
  3. trying to do a scroll window
    By AvionicsMaster1 in forum Test Area
    Last Post: - 7th September 2011, 14:00
  4. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 10:06
  5. Time window
    By Franko in forum mel PIC BASIC Pro
    Last Post: - 9th August 2005, 16:42
