LCDOUT not working at 16mhz oscillator speed.
Results 1 to 13 of 13
    Aug 2011
    Default Re: LCDOUT not working at 16mhz oscillator speed.
    Not that I see, at least not without re-writing the lib asm code.
    It looks like your display just isn't compatible with the timing of LCDOUT.
    Your method of changing the osc freq before/after using the LCD is probably the easiest "fix" that comes to mind.
    Yes, quite possible, since this is not usual 1602 LCD module - it has 3 character sets (JP, Western europe, Cyrilic), switchable just like in WS0010. It also ignores LCDOUT $FE,$0 statement. But I will try with other 1602 modules and write the results.
    Sep 2009
    Try to increase delays with defines
    ' Set command delay time in us
    DEFINE LCD_COMMANDUS 1500
    ' Set data delay time in us
    DEFINE LCD_DATAUS 44
    Already tried. Has very little impact.
  1. Define oscillator speed
    By CipiCips in forum PBP3
    Last Post: - 8th August 2016, 13:51
  2. PAUSEUS Using a 16MHz Oscillator
    By rsocor01 in forum mel PIC BASIC Pro
    Last Post: - 10th October 2013, 22:17
  3. Replies: 2
    Last Post: - 25th July 2012, 02:19
  4. High Speed Oscillator question
    By Tina10 in forum mel PIC BASIC Pro
    Last Post: - 9th July 2012, 10:29
  5. First time with external oscillator - 16F877a Not working
    Last Post: - 15th October 2009, 17:14
