LCDOUT not working at 16mhz oscillator speed.
Results 1 to 13 of 13
    Default LCDOUT not working at 16mhz oscillator speed.
    Hello. I have PIC16F1939 with the following code running.
    The LCD is common 1602 LCD, at 4 or 8mhz oscillator speed it works just fine. However, it does not work at 16mhz speed - either shows garbage symbols on screen, or some letters are missing, or nothing is shown.
    I found that changing value of DEFINE LCD_DATAUS 44 from default 44 to say 88 or 100 partially improves situation - screen works 50% times now, but still not a solution. Increasing this value more, or changing DEFINE LCD_COMMANDUS 1500 to another value does nothing.
    The only workaround I found is to switch oscillator speed before using LCD to 8mhz and then back to 16 mhz, but I don't think this is right.
    Any ideas?
    Here's the reference code.
    ;----[16F1939 Hardware Configuration]-------------------------------------------
    #IF __PROCESSOR__ = "16F1939"
      #DEFINE MCU_FOUND 1
    cfg1 = _FOSC_INTOSC           ; INTOSC oscillator: I/O function on CLKIN pin
    cfg1&= _WDTE_OFF              ; WDT disabled
    cfg1&= _PWRTE_OFF             ; PWRT disabled
    cfg1&= _MCLRE_ON             ; MCLR/VPP pin function is digital input
    cfg1&= _CP_ON                 ; Program memory code protection is enabled
    cfg1&= _CPD_OFF               ; Data memory code protection is disabled
    cfg1&= _BOREN_OFF             ; Brown-out Reset disabled
    cfg1&= _CLKOUTEN_OFF          ; CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
    cfg1&= _IESO_ON               ; Internal/External Switchover mode is enabled
    cfg1&= _FCMEN_ON              ; Fail-Safe Clock Monitor is enabled
      __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF               ; Write protection off
    cfg2&= _VCAPEN_OFF            ; All VCAP pin functionality is disabled
    cfg2&= _PLLEN_OFF             ; 4x PLL disabled
    cfg2&= _STVREN_ON             ; Stack Overflow or Underflow will cause a Reset
    cfg2&= _BORV_19               ; Brown-out Reset Voltage (Vbor), low trip point selected.
    cfg2&= _LVP_OFF               ; High-voltage on MCLR/VPP must be used for programming
      __CONFIG _CONFIG2, cfg2
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    'nixie led clock electronics direct drive
    DEFINE LCD_DREG PORTC
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 6
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE ADC_BITS 10       ' Set number of bits in result
    DEFINE ADC_CLOCK 3     ' Set clock source (rc = 3)
    ADCON1=%11110011 'enable adc internal reference and justify
    FVRCON=%11001111   'set internal reference to 4.096V
    OSCCON=%111111111   'SET INTOSC TO 16MHZ
    ANSELE=%00000000 'enable adc input porte.2
    ANSELA=%00001111 'disable ADC on A except 4
    ANSELB=%00000000 'disable ADC on B
    ANSELD=%00000000 'disable ADC on D
    TRISC=%00000000 'set PORTC as output all
    TRISD=%00000000 'set PORTD as output all
    TRISB=%00000000 'set PORTB as output all
    TRISA=%00001111 'set PORTA part as input
    TRISE=%00000000  'set PORTE as output all
    WPUB=%00000000 'DISABLE B PULL UPS
    OPTION_REG=%100000000 'disable all pull ups
    LCDCON=%00000000  'disable LCD controller pins
    LCDSE0=%00000000
    LCDSE1=%00000000
    LCDSE2=%00000000
    DEFINE OSC 16 'set oscillator speed
    lcdout $fe, $1, "test"
    stop
    Default Re: LCDOUT not working at 16mhz oscillator speed.
    That osccon looks pretty dodgy
    Aug 2011
    +1
    You're enabling the PLL with an osc freq of 16MHz, so it's trying to run at 64MHz.
    The max for that chip is 32MHz.
    Well it runs, and runs on 16mhz, I judge this by issuing HPWM 2,127,1000 statement, and measuring output frequency
    If I leave OSCCON same and set DEFINE OSC to 32mhz, then it outputs 500hz.
    Changed: OSCCON=%01111011
    Now LCD works on 16mhz, but still misbehaves sometimes - displayed characters get distorted, say you send text "TEST TEXT" and some letters will be replaced with garbage from user character area. I tried adding filtering capacitors/etc - no luck.
    OK
    You don't want filtering caps on communications lines, you want the high-low-high transitions as crisp as possible. If anything, you may adjust the SLRCONx settings.
    LOL I'm not adding filtering caps to data lines. I'm adding them to power lines
    Aug 2011
    Looking at the library code, if the clock is set for > 16MHz (or 24MHz in some cases) it uses a longer internal delay before asserting some of the control pins.
    Try this - lie to the compiler and tell it you're running faster than you really are:
    DEFINE OSC 32 'set oscillator speed
    Don't change your OSCCON setting... leave it so you're still actually running at 16MHz.
    Yes I already tried that and it works just fine, but it messes up with all other timing settings in my code, which is about 16K.
    Is there any way to adjust the library settings?
    Aug 2011
    Not that I see, at least not without re-writing the lib asm code.
    It looks like your display just isn't compatible with the timing of LCDOUT.
    Your method of changing the osc freq before/after using the LCD is probably the easiest "fix" that comes to mind.
    Yes, quite possible, since this is not usual 1602 LCD module - it has 3 character sets (JP, Western europe, Cyrilic), switchable just like in WS0010. It also ignores LCDOUT $FE,$0 statement. But I will try with other 1602 modules and write the results.
    Sep 2009
    Try to increase delays with defines
    ' Set command delay time in us
    ' Set data delay time in us
    Already tried. Has very little impact.
  1. Define oscillator speed
    By CipiCips in forum PBP3
    Last Post: - 8th August 2016, 14:51
  2. PAUSEUS Using a 16MHz Oscillator
    By rsocor01 in forum mel PIC BASIC Pro
    Last Post: - 10th October 2013, 23:17
  3. Replies: 2
    Last Post: - 25th July 2012, 03:19
  4. High Speed Oscillator question
    By Tina10 in forum mel PIC BASIC Pro
    Last Post: - 9th July 2012, 11:29
  5. First time with external oscillator - 16F877a Not working
    Last Post: - 15th October 2009, 18:14
