Can RESUME replace RETURN in a GOSUB?
Results 1 to 7 of 7
    Thank you Darrel. I thought
    IF PORTB.0 = 0 Then FlagBit = 1 : Return
    was the same as
    If it is the same, isn't it going to RETURN regardless of PORTB.0 or Flagbit? Does the first statement RETURN only when PORTB.0 = 0? Thank you. -Peter
    DOSOMETHING:
    IF PORTB.2 = 1 Then Return
    IF PORTA.5 = 0 Then Return
    GoTo DOSOMETHING 'STAY HERE UNTIL RB2, RA5 OR RB0 DOES SOMETHING
    You can have several statements on a single line and they will all be executed ONLY if the IF is true.
    IF A = B then C = A : LOW PORTB.0 : PAUSE 100 : RETURN
    Which is the same as ...
    IF A = B then
        C = A
        LOW PORTB.0
        PAUSE 100
    HTH
    Hi Darrel. You have opened up a whole new way for me to accomplish certain tasks. I migrated from a different basic compiler which doesn't support multiple commands on a single line. Being able to do this solves a lot of problems. - Peter
  1. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 12:45
  2. shifting problem
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 07:11
  3. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  4. ds1307 from f877 to f452 not work
    By microkam in forum mel PIC BASIC Pro
    Last Post: - 7th July 2005, 01:02
  5. Mssp
    By capitano in forum Code Examples
    Last Post: - 15th December 2004, 20:33
