arraywrite takes too much memory, is there any way for optmisation?
Results 1 to 7 of 7
    Default arraywrite takes too much memory, is there any way for optmisation?
    Hello.
    I'm building an educational device, which has a lot of text to display.
    Using ST7920 with own "library" to have 8 lines of 16 characters on 128x64 pixels screen.
    The issue is, that arraywrite/read takes too much memory. For example, the code below takes about 400 bytes of memory.
    if dta>olddta then arraywrite topline, ["trendi:","a]mavali          "]
    if dta<olddta then arraywrite topline, ["trendi:da]mavali           "]
    if dta=olddta then arraywrite topline, ["trendi:stabiluri           "]
    olddta=dta
    Is there any other way for storing large text lines like this? (other than using internal/external EEPROM) ?
    Default Re: arraywrite takes too much memory, is there any way for optmisation?
    What device are you using?
    nothing has changed since last time you asked the same question
    http://www.picbasic.co.uk/forum/showthread.php?t=24442
    I'm using PIC16F1939, as the biggest memory (16K and fastest (32mhz) in 16F family.
    I just came to idea - since reading external EEPROM is quite slow
    what if I use some SRAM chip, with parallel access, like CY7C199, copy data from EEPROM to it at startup, and access it as required?
    15 address pins
    8 bidirectional i/o pins
    r/w control pin
    oe pin
    ce pi
    hope you don't want the pic to do much else other than be a pin jockey for all them controls
    and you think that will be easier to get going than learning to use flash memory
    Yes it will take a lot of pins.
    I'm using I2CREAD/I2CWRITE w/o any issues, but it is slow.
    Flash memory is more manageable as Richard noted.
    Observe how selected PIC is controlling read/write pages and do it nice and fast.
  1. how much space it takes up
    By longpole001 in forum PBP3
    Last Post: - 29th April 2014, 11:42
  2. ARRAYWRITE lenght
    By pedja089 in forum mel PIC BASIC Pro
    Last Post: - 16th June 2012, 15:45
  3. 18F4550 USB takes over
    By milosch in forum USB
    Last Post: - 27th March 2011, 14:17
  4. Replies: 11
    Last Post: - 17th August 2010, 16:45
  5. SEROUT2 takes 1400ms to execute?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 16th March 2006, 17:08
