Confusion with 18F45K80 config, maybe someone has working one?
Results 1 to 10 of 10
    Aug 2011
    Default Re: Confusion with 18F45K80 config, maybe someone has working one?
    Judging from your settings I'm going to assume you're trying to use the INTOSC.
    If so, you need to set the CONFIG to use it. That's what controls what happens at powerup...
    trying to setting the OSCCON register is a run-time setting, so it relies on the thing running in the first place.
    The default INTOSC setting is 8MHz, so it'll run at that speed until you change it with OSCCON.
    Try this:
      CONFIG  RETEN=ON, INTOSCSEL=HIGH, SOSCSEL=HIGH, XINST=OFF, FOSC=INTIO2, PLLCFG=OFF
    'then later you can change it
    OSCCON = $70     ' IRFC[2:0] = 111 (16MHz), SCS[1:0] = 00 (primary CONFIG osc setting)
    ' set PLLEN (optional, 4x16MHz=64MHz)
    'OSCTUNE.6 = 1
    Thanks!
    I will try it today later.
    I want to run it at 16mhz and then try 64mhz, to see if there's any practical difference in i2cread and shiftout statements, since on 16F, oscillator speed has no impact on these statement speed, which is around 50khz, whenever oscillator is 4mhz or 16mhz.
    OSCTUNE.6 = 1
    DEFINE OSC 16
    'ANSELE=%00000000 'enable adc input porte.2
    'ANSELA=%00000010 'disable ADC on A
    'ANSELB=%00000000 'disable ADC on B
    'ANSELD=%00000000 'disable ADC on D
    ANCON1=0 'DISABLE ADC D3-D2-D1-D0-
    TRISC=%00000000 'set PORTC as output all           0.
    TRISD=%00000000 'set PORTD as output all
    TRISB=%00000000 'set PORTB as output all
    TRISA=%00000000 'set PORTA 2 as input, others as output
    TRISE=%0000000  'set PORTE as output all
    GKO:
    HIGH PORTd.0
    PAUSE 2000
    LOW PORTd.0
    PAUSE 2000
    GOTO GKO
    Still does not work. In this example, PORTD.0 measures 2.5 volt and does not change.
    same to any other port.
    Aug 2011
    Sorry, I didn't mean for you to get rid of the other CONFIG settings... just change the OSC ones.
    Here's a complete example
      CONFIG  FCMEN=OFF, IESO=OFF, PWRTEN=OFF, BOREN=SBORDIS, BORV=3, BORPWR=ZPBORMV
      CONFIG  WDTEN=SWDTDIS, WDTPS=512, CANMX=PORTB, MSSPMSK=MSK7, MCLRE=OFF
      CONFIG  STVREN=ON, BBSIZ=BB2K, CP0=OFF, CP1=OFF, CP2=OFF, CP3=OFF, CPB=OFF
      CONFIG  CPD=OFF, WRT0=OFF, WRT1=OFF, WRT2=OFF, WRT3=OFF, WRTC=OFF, WRTB=OFF
      CONFIG  WRTD=OFF, EBTR0=OFF, EBTR1=OFF, EBTR2=OFF, EBTR3=OFF, EBTRB=OFF
    OSCTUNE.6 = 1
    'with PLLEN=1
    DEFINE OSC 64
    'with PLLEN=0
    'DEFINE OSC 16
    ANCON0=0	' digital IO AN7-AN0
    ANCON1=0 	' digital IO AN8-AN14
    TRISA=%00000000 'set PORTA as output all
    GKO:
    HIGH PORTD.0
    PAUSE 2000
    LOW PORTD.0
    PAUSE 2000
    GOTO GKO
    If you're using a DVM and measuring 2.5V, that probably means the pin is toggling but it's too fast for the meter,
    so the 'DEFINE OSC' doesn't match your actual settings and the 'PAUSE' is wrong.
    Try increasing the pause time to 5000 or 10000
    You'll see a difference, but it likely won't be earth shattering.
    To really effect the I2C speed you'd need to switch to using the MSSP hardware, and while that SHOUT routine I posted is faster than shiftout, it won't be as fast as using the SPI peripheral.
    I will try to check it with scope next week, but my multimeter is Amprobe PM55A, it can do 5 samples per second and actually works even with pause 200
    MSSP might be good, but I was not able to run any of code samples given here on 16F series and I was not able to start any 18F series chip at all
    Aug 2011
    Just try changing the on-off pause statements so that it's not 50 % duty cycle.
    Pause 2000, pause 6000 or pause 6000,pause 2000 should get you a different reading if the output is actually changing.
  1. RS-232 confusion
    Last Post: - 17th March 2015, 16:16
  2. Servo confusion
    By Ramius in forum General
    Last Post: - 28th May 2012, 01:41
  3. setting config fuses not working
    By queenidog in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2012, 15:30
  4. HPWM confusion
    By lerameur in forum General
    Last Post: - 5th November 2006, 11:09
  5. HPWM confusion
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2005, 17:50
