Speed optimization (framebuffer scrolling)
Results 1 to 17 of 17
    Default Re: Speed optimization (framebuffer scrolling)
    I should use it as a learning exercise though as I do feel the need to better understand ASM.
    its worth the effort
    this just under 100uS for a iteration
    '*  Author  : richard                                           *
    '*  Notice  : Copyright (c) 2022 caveat emptor                  *
    '*  Date    : 11/10/2022                                        *
      CONFIG  FOSC = INTIO67
      CONFIG  PLLCFG = ON
      CONFIG  PRICLKEN = ON
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = ON
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 190
      CONFIG  WDTEN = OFF
      CONFIG  WDTPS = 32768
      CONFIG  CCP2MX = PORTC1
      CONFIG  PBADEN = OFF
      CONFIG  CCP3MX = PORTB5
      CONFIG  T3CMX = PORTC0
      CONFIG  HFOFST = ON
      CONFIG  P2BMX = PORTB5
      CONFIG  MCLRE = EXTMCLR
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
        DEFINE OSC 64
        DEFINE DEBUG_REG PORTB
        DEFINE DEBUG_BIT 7
        DEFINE DEBUG_BAUD 9600
        DEFINE DEBUG_MODE 0
        LATB.7=1
        bcnt       VAR BYTE   bank0
        dcnt       VAR BYTE   bank0
        BUFF       VAR BYTE[32]
        iteration  VAR word
        OSCCON=$70
        OSCTUNE.6=1
        while ! osccon2.7 :WEND    ;wait for pll
        ANSELB=0
        ANSELC=0
        ANSELA=0
        dspbuff var byte[380]
        clear
        trisc = %01111111
        TRISB = %01111111
        TRISA = %11111111
        debug 13,10,"ready",13,10
         LATc.7=0
         ;38x8 bits wide 10 bits high
         dspbuff[379]=$c0
         dspbuff[37]=$c0
    LATc.7=1; trigger oscilloscope
    gosub rotate_r
    LATc.7=0
    debug 13,10,dec iteration
    debug 13,10,bin8 dspbuff[379]," " ,bin8 dspbuff[378]," " ,bin8 dspbuff[343] ," ",bin8 dspbuff[342]
    debug 13,10,bin8 dspbuff[37] ," " ,bin8 dspbuff[36] ," " ,bin8 dspbuff[1]   ," ",bin8 dspbuff[0]
    pause 200
    iteration=iteration+1
    rotate_r:  ' pic18    100uS
    asm
        banksel _bcnt    ;ROW
        movlw   10       ;10 rows
        movwf   _bcnt
        movlw   high (_dspbuff)
        movwf   FSR0H
        movlw   low  (_dspbuff)
        movwf   FSR0L
        movlw   123        ;BUFFER SIZE low byte  (380-1) 36 displays + 2 outside of display * 10-1
        ADDWF   FSR0L
        movlw   1        ;BUFFER SIZE high byte  (380)
        ADDWFC   FSR0H
        MOVLW 38     ;36 displays + 2 outside of display
    NROW
        movwf   _dcnt
        bcf    STATUS, C
    Ncol
        rrcf   POSTDEC0 ,f     ;PER COLUMN
        DECFSZ  _dcnt ,F
        BRA    Ncol
        BNC    NBNC
        bsf    PLUSW0,7     ;max displays would be 127 to use plusw
    NBNC
        DECFSZ  _bcnt ,F
        BRA    NROW
        banksel 0
    endasm
    Thanks Richard,
    What device did you run this on?
    After being unseccessfull in integrating your version into my code I tried to get your code (I removed some oscillator specific stuff to match my device) to compile for the 57Q43 but it won't.
    It can't fit bcnt/dcnt into bank 0 so I tried various banks. Bank 5 works but I still get [ASM WARNING: ASM-SCROLL.ASM (411) : Invalid RAM location specified]
    Line 411 in the .asm listing is banksel 0 in the NBNC routine.
    I know it says warning and not error but the description sounds bad enough :-)
    See, this is what I mean....
    For reference, here's what I'm trying to compile for the 57Q43:
    DEFINE OSC 64
    DEFINE DEBUG_BIT 7
    DEFINE DEBUG_MODE 0
    LATB.7=1
    bcnt       VAR BYTE   bank0
    dcnt       VAR BYTE   bank0
    iteration  VAR word
    ANSELB=0
    ANSELC=0
    ANSELA=0
    clear
    trisc = %01111111
    TRISB = %01111111
    TRISA = %11111111
     LATc.7=0
     dspbuff[379]=$c0
     dspbuff[37]=$c0
    gosub rotate_r
    LATc.7=0
    pause 200
    asm
        banksel _bcnt    ;ROW
        movlw   10       ;10 rows
        movwf   _bcnt
        movwf   FSR0H
        movwf   FSR0L
        ADDWF   FSR0L
        ADDWFC   FSR0H
    NROW
        movwf   _dcnt
        bcf    STATUS, C
    Ncol
        DECFSZ  _dcnt ,F
        BRA    Ncol
        BNC    NBNC
    NBNC
        DECFSZ  _bcnt ,F
        BRA    NROW
        banksel 0
    endasm
    18f26k22
    i have not tried much with Q43 yet , but
    they have no ram below bank 5.
    i dont know what bank pbp defaults to for them bank0 makes no sense at all , before them pbp kinda assumes bank0 before and after calls.
    the instruction set is slightly different. movfffl or whatever
    there may be other weird shit with indirect addressing
    i have some q43's i just lack the enthusiasm to learn about them when the tried and trusty k22 serves my needs
    try them in bank6
    and just remove the banksel 0 at the end
    i added a rotate left to and a few tweaks
    '****************************************************************'*  Name    : UNTITLED.BAS                                      *
    '*          : pic18f26k22                                                  *
      CONFIG  PLLCFG = ON
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = ON
      CONFIG  BORV = 190
      CONFIG  WDTEN = OFF
      CONFIG  PBADEN = OFF
      CONFIG  HFOFST = ON
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
        NumberOfDisplays  CON 36
        NumberOfRows  CON 10
        DEFINE OSC 64
        DEFINE DEBUG_BIT 7
        DEFINE DEBUG_MODE 0
        LATB.7=1
        bcnt       VAR BYTE   bank0
        dcnt       VAR BYTE   bank0
        BUFF       VAR BYTE[32]
        iteration  VAR word
        OSCCON=$70
        OSCTUNE.6=1
        ANSELB=0
        ANSELC=0
        ANSELA=0
        clear
        trisc = %01111111
        TRISB = %01111111
        TRISA = %11111111
        LATc.7=0
        iteration=0
        dspbuff[379]=3
        dspbuff[37]=3
        WHILE  iteration<610
            LATc.7=1
            gosub rotate_l
            LATc.7=0
            pause 50
        WEND
        iteration=0
        dspbuff[379]=$c0
        dspbuff[37]=$c0
        WHILE  iteration<610
            LATc.7=1
            gosub rotate_R
            LATc.7=0
            pause 50
        WEND
    rotate_r:  ' pic18
    asm
        banksel _bcnt  ;ROW
        movlw   _NumberOfRows    ;10 rows
        movwf   _bcnt
        movlw   high (_dspbuff)  ;BOTTOM OF BUFFER
        movwf   FSR0H
        movwf   FSR0L
        movlw   low((_NumberOfDisplays + 2)*_NumberOfRows-1) ;TOP OF BUFFER
        ADDWF   FSR0L
        movlw   high((_NumberOfDisplays + 2)*_NumberOfRows-1)
        ADDWFC  FSR0H
        MOVLW   _NumberOfDisplays + 2;36 displays + 2 outside of display
    RROW
        movwf   _dcnt        ;display
        bcf     STATUS, C
    Rcol
        rrcf    POSTDEC0 ,f  ;PER display
        DECFSZ  _dcnt ,F
        BRA     Rcol
        BNC     RBNC
    RBNC
        DECFSZ  _bcnt ,F
        BRA     RROW
        banksel 0
    endasm
     rotate_l:  ' pic18
    asm
        banksel _bcnt              ;ROW
        movlw   _NumberOfRows
        movwf   _bcnt
        movwf   FSR0H
        movwf   FSR0L
    LROW
        comf    WREG
        incf    WREG
        bcf     STATUS, C
    Lcol
        rlcf    POSTINC0 ,f   ;PER display
        DECFSZ  _dcnt ,F
        BRA     Lcol
        BNC     LBNC
        bsf     PLUSW0,0       ;max displays would be 127 to use plusw
    LBNC
        DECFSZ  _bcnt ,F
        BRA     LROW
        banksel 0
    endasm
    with my suggestions it compiles for 18f47q43, whether it works is not tested . a quick browse of the q43 instruction set and access bank looks ok
    Bank 6 (or 7) doesn't work at all. I don't know what it's doing exactly. It does display the text but it does not scroll it.
    Bank 5 (or 25) works - sort of.
    I can scroll it left OR right continously without issues but when I change direction whatever is in the non visible part the buffer comes back on to the display shifted down by one row - at least I think that's what happening.
    But it's fast, that's for sure.
    * Mine was like 7ms or something like that
    * tumblweeds was more than twice as fast at 3ms.
    * Richards comes in at 0.2ms - amazing.
    Mine and tumbleweeds simply scrolls the display, anything that's shifted outside of the buffer is lost while Richards rotates it so they're not exactly the same.
    Aug 2011
    On most of the Q family the SFR registers are in banks 0-4, and the start of user ram is in bank 5.
    That's where the access bank is (0x500-0x55F). The other part of the access bank is at 0x460-0x4FF, but that's for the fast SFR registers so you can't use that.
    So, the "default" setting for 'banksel' should be 5 and not 0.
    If you use the MOVFF instruction both the source and destination must be in the first 4K of ram space.
    If either are outside that you need to use MOVFFL, which is a three-word instruction so it's more code (and slower) than MOVFF.
    The K42/K83 force you to use MOVFFL to access SFR registers outside the access bank since on those the SFR regs are at the very top of ram.
    That's one reason to skip the K42 and use the Q43 instead.
    i expected to have had the buffer cleared out and reset before a direction change . however that sort of behavior is unanticipated
    i get 0.1mS , maybe my oscilloscope is off
    one of my clients sent me a test jig for q43 chips yesterday. i need to get into them soon i guess
    no more excuses
    @tumbleweed for confirming what i thought
  1. Re:Scrolling speed control problem in moving message display
    By machobob in forum mel PIC BASIC Pro
    Last Post: - 19th June 2010, 13:08
  2. Replies: 0
    Last Post: - 7th August 2008, 10:02
  3. code size VS speed optimization setting?
    Last Post: - 28th April 2008, 15:38
  4. While we're on the subject of optimization...
    Last Post: - 11th March 2008, 13:51
  5. Multiple if then optimization
    By Mugelpower in forum mel PIC BASIC Pro
    Last Post: - 5th March 2008, 13:15
