Adapt MELABS DS18B20 example to show negative temperatures?
Results 1 to 6 of 6
    Default Re: Adapt MELABS DS18B20 example to show negative temperatures?
    what part of this have you failed to understand
    http://www.picbasic.co.uk/forum/showthread.php?t=24650
    I just had no idea same can be applied to DS18B20 readings
    What should be fixed there to display negative temperature properly?
    As I've read DS18B20 datasheet, negative temperature output will always have 4 MSB bits set to 1111. But what's wrong with the above conversion formula?
    you may have read the DS18B20 datasheet but you are using code for a DS18S20 so the first step is work out what you really have and then use the correct method
    Well I have it running with DS18B20 and it displays positive temperatures just fine...
    I also used this:
    https://melabs.com/samples/LABX1-16F...emp_DS1822.htm
    But it is much slower.
    And I don't need high precision, this is just room temperature thermometer, 1C precision is ok.
  1. Why does PICkit2 show it as an LF device?
    By Balachandar in forum mel PIC BASIC Pro
    Last Post: - 21st October 2018, 15:28
  2. Best way to read multiple temperatures?
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 29th May 2012, 21:07
  3. How to compare two temperatures
    By SKOLS1 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2012, 09:07
  4. How do I compare two temperatures
    By critix in forum Code Examples
    Last Post: - 4th January 2011, 12:42
  5. DS18S20 displays wrong temperatures
    By Shozo Kanamori in forum mel PIC BASIC Pro
    Last Post: - 6th August 2007, 03:18
