Fast bit doubling, how?
Results 1 to 9 of 9
    Default Fast bit doubling, how?
    Hello. Most likely, I asked this before, but can't find the topic
    The top is the original variable, represented in bit form.
    The bottom is desired result. It is just each bit doubled, so final result occupies two bits.
    11110011 11110011
    Technically, I've done it a way that each bit of input variable is read, then written into another variables two times, next to each other.
    This indeed works, but it is very slow. Is there any other method of achieving this?
    I need this for font scaling..
    Default Re: Fast bit doubling, how?
    Define very slow so we have something to compare against.
    outvar.0 = invar.0
    outvar.1 = invar.0
    outvar.2 = invar.1
    outvar.3 = invar.1
    outvar.4 = invar.2
    outvar.5 = invar.2
    outvar.6 = invar.3
    outvar.7 = invar.3
    outvar.8 = invar.4
    outvar.9 = invar.4
    outvar.10 = invar.5
    outvar.11 = invar.5
    outvar.12 = invar.6
    outvar.13 = invar.6
    outvar.14 = invar.7
    outvar.15 = invar.7
    The above brute force version takes <4.1us @64MHz. Extrapolating to 4MHz = 66us or 15150 times per second.
    I don't think I can come up with a faster PBP version, perhaps some ASM guru can but knowing you you don't want that :-)
    Well, screen buffer if 128x64 pixels. That's 16x64 bytes, that's 1KB.
    Since I can't keep it in memory, it is "rebuilt" on the fly, each time display updates.
    I'm not doing any smooth scrolling or FX, so 5 fps should be enough.
    The routine works as follows - text is read from array letter by letter, appropriate location of EEPROM is read, to get font data, which is then sent to display. With "my" method, it takes approximately 1.2 seconds to redraw whole display. I'll check tomorrow this method and post back about the speed.
    Well, if the screenbuffer is 1kB it means that you're converting 512 bytes to "double bytes". Even at 4MHz that conversion can be done 30 times/second.
    If the refreshing the screen takes 1.2s (!) this "bit doubling" is only ~3% of that time. The bottleneck is elsewhere.
    Yes, it is in my code, because I was doing manual reading of bits
    will fix it today
    Aug 2011
    Even though it looks longer, this should end up almost twice as fast...
    outvar = 0
    if (invar.0) then
        outvar.0 = 1
        outvar.1 = 1
    if (invar.1) then
        outvar.2 = 1
        outvar.3 = 1
    if (invar.2) then
        outvar.4 = 1
        outvar.5 = 1
    if (invar.3) then
        outvar.6 = 1
        outvar.7 = 1
    if (invar.4) then
        outvar.8 = 1
        outvar.9 = 1
    if (invar.5) then
        outvar.10 = 1
        outvar.11 = 1
    if (invar.6) then
        outvar.12 = 1
        outvar.13 = 1
    if (invar.7) then
        outvar.14 = 1
        outvar.15 = 1
    I think #2 is faster.
    Aug 2011
    It can depend on the device and where the variables end up, but here's a contrast of the two methods (post #2, post #6)
    invar    #2    #6
    $00      64    34
    $01      64    36
    $55      64    42
    $FF      64    50
    That's for an 18F26K22. Results are in instruction cycles.
    Post #2 has the "advantage" of always taking 64 cycles, but #6 is always faster.
    Impressive!
  1. Replies: 10
    Last Post: - 8th March 2015, 19:26
  2. Replies: 17
    Last Post: - 22nd May 2014, 19:58
  3. Doubling the pusle count
    Last Post: - 17th May 2012, 13:17
  4. Help! sinking fast!
    By fowardbias in forum mel PIC BASIC Pro
    Last Post: - 31st May 2007, 19:39
  5. A/D on 16F877. How fast can I go?
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 8th April 2004, 06:51
